Tekno RC EB48 Thread >
Like Tree2Likes
Old 10-07-2012 | 07:52 AM
  #2821
SEF's Avatar
SEF
Default kyosho springs
It seems like using light blue Kyosho spring front and rear is THE setup for any 1/8 scale these days. Kyosho and Associated uses them. I've seen Mugen and Xray use them. I own a few K cars and have all the springs, so I figure I would do some testing.
I did my testing at Revelation Raceway, a large 1/8 track with 200 ft straight, huge jumps, fast but technical, hardpacked with a loose loamy/sandy top layer.
First off, by feel alone, the light blue springs are significantly stiffer than stock springs. I did not like the feel of them front AND rear. Suspension was too stiff. It didn't handle the rough bumpy surface that well, and the rear end was a little unpredictable. I did like the blue spring up front. A stiffer spring up front felt great, but I ended up going back to stock rear spring. The stock rear spring drove the same as a Kyosho orange spring. The two feel almost identical.
So in the end, my fastest lap times came from changing the stock front spring to something stiffer (in this case, a Kyosho light blue front spring), and keeping the rear end stock (or can use Kyosho orange springs).
SEF is offline
Old 10-07-2012 | 11:40 AM
  #2822
Anyone willing to help me pick batteries? This is my first 1/8 scale, first time running 4s, and I really want a well balanced car. I listed my e-setup back a page.
The kit will be here Friday so the sooner I pick batteries the better
TIA
sffan15 is offline
Old 10-07-2012 | 12:51 PM
  #2823
TIA
Protek 4100. It balances the car great left to right and will give you about 13 minutes of runtime.
Kane-o is offline
Old 10-07-2012 | 01:14 PM
  #2824
teknorc's Avatar
Ditto.
teknorc is offline
  #2825
Are you saying that based on my electronics? Or just in general?
Thanks for your reply.
Joey
sffan15 is offline
Old 10-07-2012 | 01:41 PM
  #2826
protc3's Avatar
I just got back from the track now. The car is ready for the big state series race next weekend. I went with serpent blue front spring and yellow rear. I am running a different setup now as I feel it is much better for the new track layout. It still has big jumps but its much more flowing and fast. There are a lot of switchbacks so I went with short camber links. I will put together a new setup sheet after this race. Should be close to 60 e buggies.
protc3 is offline
Old 10-07-2012 | 02:54 PM
  #2827
Originally Posted by teknorc
Ditto.
You mean the 2x 2S shortys?
sffan15 is offline
Old 10-07-2012 | 04:48 PM
  #2828
Afun's Avatar
TIA
Team Epic Revtech 4s 6500mah 70c Battery is orange hard case. Only 110 at Absolute Hobbyz. I have the double deuce for the b4.1 and its awesome. Real punchy. I just bought one for the eb48
Afun is offline
Old 10-07-2012 | 05:18 PM
  #2829
Afun's Avatar
Chris,
Does it seem to hit an equilibrium at 150 with that gearing, or if you ran an extra 5 minutes would it come off even hotter?
With my skill level, I often prefer to give up a little speed/power to have slightly lower temps, such that I can run and run without worrying about burning up a motor (also goes back to my cheapskate nature, I hate burning up components/breaking parts). Speaking mostly to practice sessions. During a race I will probably use your gearing either way.
Joey
Joey,
Are you running the radiopost blue for steering in the eb48? Do you think it has enough torque for the application? I will have one for steering too.
Afun is offline
Old 10-07-2012 | 06:05 PM
  #2830
TIA
I have the Gens Ace 5000s, and they work pretty good.
http://www.hobbypartz.com/98p-40c-50...se-direct.html
Stormer has these on sale now. http://www.stormerhobbies.com/cgi-bi...=ns&pn=TEP2105. I have two, and they are great.
These look very interesting.....http:// http://www.valuehobby.com/power-systems/lipo-batteries/car-lipo-hard-case/gforce-60c-5200mah-4s-car-lipo.html
rcmiket is offline
Old 10-07-2012 | 06:47 PM
  #2831
teknorc's Avatar
Protek 4100 /4s single pack. I don't like the 2x shorty setups all that much. Too many wires :-)
teknorc is offline
Old 10-07-2012 | 07:04 PM
  #2832
Originally Posted by Afun
Joey,
Kit is in the mail. That's the servo I have. I worry about the torque, trying to trade it for a green tbh
sffan15 is offline
Old 10-07-2012 | 07:07 PM
  #2833
jones8352's Avatar
TIA
I've been playing with balance too. Right now I'm runing a Castle mmp esc with a Tekin 2050 motor with a Gen Ace 4000mah 60c 4c pack. I can get around 14 to 15 min on a track that has a 170' front straight. That pack weighs 473 grams and it's a soft pack which works fine for most club racing. Right now the price of that soft pack is $59.31. If I need a R.O.A.R. pack I use the Gen Ace 40c 5000mah hark pack that weighs 562 grams that're right at $56.75 right now. I ran my new eb48 and both my v4 d8 and my v4 d8t at our home track today that's 130'x90' and had a blast today. It would be nice to go to the track we race on but it's a 120 miles south of my home. I really like the way my eb fly's but I still can't get it to hook up as good as my v4. At our last race of the season I got creamed, came in dead last. I averaged about 2 seconds per lap slower than my v4-d8. The races b4 that I had awesome finishes. Our track can be rough so the light weight of the eb is a handicap at times.
jones8352 is offline
Old 10-07-2012 | 08:50 PM
  #2834
Originally Posted by jones8352
I've been playing with balance too. Right now I'm runing a Castle mmp esc with a Tekin 2050 motor with a Gen Ace 4000mah 60c 4c pack. I can get around 14 to 15 min on a track that has a 170' front straight. .
Does the pack fit well in the battery tray? I was worried the wires coming out the side of the battery would be a problem.
james633 is offline
Old 10-08-2012 | 03:53 AM
  #2835
v1r killer's Avatar
Need help on my pinion size to run, on med to large outdoor track on 4s 2050 tekin and rx8 standard spur gears, not sure on what the base pinion should be?
v1r killer is offline
