What Method Do You Use Changing Diff Oils >
Like Tree6Likes
Old 01-18-2012, 10:55 AM
Default What Method Do You Use Changing Diff Oils
Im curious how people go about removing the old oils from diffs when you want to change to a new weight. Do you just tip it out and leave all the parts still coated and tip in the new stuff to mix with it, or do you give each individual part a clean? How do you go about that?
Its a crappy job, I hate doing it so any tips to make it easier are welcome.
roylo is offline
Old 01-18-2012, 11:01 AM
lowroad's Avatar
Trader Rating: 79 (100%+)
Ugh, my least favorite thing. Dump it all out, tear down the diff completely, soak all metal in degreaser, and all plastic in simple green, either overnight, or until all crud is gone. Rinse it all off, reassemble, and fill. I mean it's not that bad, but that's how I do it. It's just not exactly fast. It's probably overkill, but that's my personal mehtod.
lowroad is offline
Old 01-18-2012, 11:02 AM
Jerm13's Avatar
Trader Rating: 36 (100%+)
Pull the diff out, I remove the internals and put them on a clean rag, use a couple of q-tips to get the old oil out and then spray a little motor/ carb/ brake clean to finish it off. Then a quick spary on the internals. As I reassemble, I install the gears first and then fill it with oil. rotate the one out drive to help get the bubbles out ( it take a little while when using anything highr that 7K). Let it sit for a few then top it off and seal it up.
Diffs are messy no matter how you do it. I do mine the 1st and 3rd week of the month and the shocks the 2nd and 4th week durring the heavy summer racing months.
Jerm13 is offline
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
I just pull all of the parts and wipe them with a cotton towel. You can leave the gears, blocks and shims on the cross pins if you hold the pins by the ends while you roll the gears between your fingers. The sun gears and cases just get a quick wipe and 99% of the old oil is gone.
ZEe_NYC and jpcopeland1 like this.
ChrisAttebery is offline
Old 01-18-2012, 11:03 AM
Trader Rating: 23 (100%+)
Sometimes just a quik refill and every so often a total clean out
nitro0619 is offline
Old 01-18-2012, 11:08 AM
mkiiina's Avatar
Trader Rating: 71 (100%+)
Pretty much how I do it. Sometimes I'll go whole hog and bust out the dawn and a toothbrush if the diff failed in spectacular fashion. If not just a quick wipe I find gets almost everything out.
Some diffs are easier than others. My Hyper TT's are a breeze while the ones in my Revo (and MERV for that matter...) I'd almost buy new ones....almost. such a pain!
mkiiina is offline
Old 01-18-2012, 11:10 AM
Trader Rating: 19 (100%+)
For quick at the track oil changes I just dump the oil and wipe off as much as possible.
At home I have a neat tool that started life as a tea infuser- basically a hinged mesh ball that I can put parts into and briskly swish it around in a jar of mineral spirits. (Old pickle jars work well) I have another jar with acetone for a final rinse that leaves everything dry and film free. For the diff case I wipe it out, brush the small crevices out with a small paint brush (with shortened bristles) and blow it off with motor spray. Check/replace orings and reassemble.
Jonny5 is offline
Old 01-18-2012, 11:30 AM
tc5 man's Avatar
I just take everything apart in the diffs and sit aside the o-rings and put the gears and diff cup into a container and spray white lighting degreaser on them and let it soak than whipe it off than spray simple green on it wipe it off again bam all the old oil is off .
Jerm: I asked somebody on here about if i need to get all the air bubbles out of the diff oil and the person told me on here not to worry about it because if you have no air in the diff oil it will break down unexpectly ? When i fill my diffs up with oil i do let them sit to settle so i know that gets the air out also.
tc5 man is offline
Old 01-18-2012, 11:58 AM
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Yeah no need to have all air bubbles out in a diff. Most manuals recommend diffs be filled only upto wetting all the planetary gears so probably a ~0.75 mm air void. I let mine settle down quicker by spinning the cup side outdrives.
aloksatoor is offline
Old 01-18-2012, 12:06 PM
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Default buy this
I really thought someone was gonne mention this.
You'll thank me after the first time.
http://www.gmksupply.com/html/gmk0112.html
nitrobeast is offline
Old 01-18-2012, 12:18 PM
I have the GMK diff dunker and a jar of naptha. I'll usually pull the gears out, and clean them, then mix in some low viscosity shock oil to thin the fluid then dump it out and whisk everything in the Naptha. It takes forever. I may try the soaking method, but it would be nice if there was a quick and simple way that I could clean 3 diffs in 10 minutes. The diff dunker works well, but I wish it were larger, usually takes 2-3 "loads" to clean a diff.
AMorgan is offline
Old 01-18-2012, 12:40 PM
Automatic trans fluid flush chemical in a small jar....drop in all diff parts....shake it up and soak for 5 mins and clean as new
Old 01-18-2012, 12:46 PM
That's not such a bad idea.
They have things like that for making tea. I'm sure Target or Walmart or Bed Bath and Beyond have a bunch of things similar to that.
Wildewinds is offline
Old 01-18-2012, 01:14 PM
Disassemble, wipe most of it off, diff dunker into Naptha. Way easier then the other ways. Though, I used to just hose it all down with non-chlorinated brake cleaner, that did a good job too.
WindDrake is offline
Old 01-18-2012, 05:31 PM
jmackani's Avatar
Trader Rating: 14 (100%+)
Turn upside down in a container for a minute. Take the air compressor to the rest. All while leaving the parts in the diff. I have the tried the naptha method and I am not convinced it's breaking down the oils any better. This air compressor method is much faster.
jmackani is offline
