RC10T4.1 Thread.
Old 03-14-2012 | 07:29 PM
  #826
idrummerboy13's Avatar
r u guys running pl molded inserts like you would on the buggy? Ill be glueing blue barcodes and not sure if i should but the open cell in
med hite indoor wet to dry clay
idrummerboy13 is offline
Old 03-14-2012 | 07:44 PM
  #827
DaveW's Avatar
As smooth as your track is you can prolly get away with it. I only run moldeds in 1/8th.
DaveW is offline
Old 03-14-2012 | 08:24 PM
  #828
Jake S's Avatar
indoor clay im running slicks w/ proline closed cell w/ stock foams shoved under them. sounds like it should be really stiff, but its not really. stiffer then a bomb one firm tho.
the other option is to wrap tape around the rim (i fill up till its level with the edge of the rim when i do this)
Jake S is offline
Old 03-15-2012 | 02:24 PM
  #829
Drtdvl5's Avatar
Ok, so as many as us AE t4.1 drivers know, the stock servo that comes in the rtr kit really sucks. I should have found an alternative after the first one gave way, but didn't. I just went thru my fourth SHV1504MG servo today, and now have had enough. What kinda servos have y'all found as an upgrade for the t4.1? I'm looking for a higher torque and speed servo. And does anyone know of any manufacture that sells blue anodized servos? I've seen silver.. Thanks guys
Lee
Drtdvl5 is offline
Old 03-15-2012 | 02:28 PM
  #830
bds81175's Avatar
Moderator
I love the Savox 1258. Super fast and plenty strong. I also just tried out an MKS DS1210 and so far I have been pretty happy with it and its quite a bit cheaper. Neither fit the blue anodized criteria though.
bds81175 is offline
Old 03-15-2012 | 02:42 PM
  #831
Drtdvl5's Avatar
Thanks..I've never heard of MKS, but I've heard alot about savox. Sounds like there are quite a few people who swiched their stock servo to a savox...is 1258 the correct model for the t4.1 application?? Thanks for your input.
Drtdvl5 is offline
Old 03-15-2012 | 03:43 PM
  #832
im ganna fill the rim with tape and see how that goes. Blues are working well on everything else. Cant stand pinks.
Old 03-15-2012 | 04:08 PM
  #833
bds81175's Avatar
Moderator
MKS commonly has banner adds on RC Tech. Like I said, its a decent servo and I only paid $35 for it. Seems like quite a steal. The Savox 1258 would be perfect for a T4. Tons of torque and super fast.
bds81175 is offline
Old 03-15-2012 | 04:16 PM
  #834
Drtdvl5's Avatar
Thanks for the input. Just ordered a savox
1258TI from A-Main!
Drtdvl5 is offline
Old 03-15-2012 | 04:22 PM
  #835
Drtdvl5's Avatar
Originally Posted by LoudOne
Speaking of shocks, I'm surprised no one here has tried out the Proline Power Stroke Big Bore shocks. I run them in my T4 and woudn't go back to anything else. The only mod I did was to put some RPM limiters on the inside of the shock body..
Did you have to use the adapter kit to fit your t4? Or did they go right on.. What oil weights are you running? Spring set up? And which rpm limiters did you use? i Like the setup and I'm experimenting with my PLs trying to dial them in.. Thanks
Drtdvl5 is offline
Old 03-15-2012 | 06:49 PM
  #836
Originally Posted by Cain
if you want to see how the effect of limiting the droop would be, I have heard you could run zip ties to limit the travel and then based on what you find, you can make it more permanent by putting limiters in the shocks themselves.
how would this work?
gguertin145 is offline
Old 03-15-2012 | 08:44 PM
  #837
Jake S's Avatar
any find any other springs other that rt5 or 22t springs that work on the front?
the green 22t spring seems too soft for the front.
Jake S is offline
Old 03-15-2012 | 09:36 PM
  #838
njnewc's Avatar
FYI, the Align 610 is Blue Anodized... It works great... Check it out...
http://www.servodatabase.com/servo/align/ds610
njnewc is offline
Old 03-15-2012 | 10:13 PM
  #839
darryl80's Avatar
Cool
i got my b4.1 in the mail and wondering if a novak ballistic 17.5 motor will be a good motor for it.
darryl80 is offline
Old 03-15-2012 | 10:29 PM
  #840
Joyridn's Avatar
1258TI from A-Main!
I'm running the savox as well, great servo!
Joyridn is offline
