RC10T4.1 Thread.
Old 03-13-2012 | 06:17 PM
  #811
Jake S's Avatar
Originally Posted by SirKarnage
By doing this you should not have a loss of steering, and you will also save your servo in the process.
it also makes your steering react faster because the servo isnt going as far from loc-to-loc. so it gives you the feel of MORE steering
Jake S is offline
Old 03-13-2012 | 08:20 PM
  #812
DaveW's Avatar
Jake... you have a spare older T4 rear tower to compare to the one on the back of your truck now? My LHS doesnt have one in stock and im curious if my 4th drilled hole is off...
Its hard to see here but you get the idea...
DaveW is offline
Old 03-13-2012 | 09:06 PM
  #813
Jake S's Avatar
the newer towers on the truck do not have the "4th hole" added, you still need to drill it if you want to run it
best way to do it is if you have a tower that ever broke, just cut the 3 holes off, then mount it to the tower you want to drill via two 4-40 screw and atleast one nut.
but imho it looks pretty close, if anything its 4.1th hole not a 4th hole :P [aka inward alittle extra]
Jake S is offline
Old 03-14-2012 | 07:38 AM
  #814
Ralph289's Avatar
Default t4 Droop Adjustment ??
New guy here, is there a adjustment for droop on a rc10t4 in the rear ?
If not can you add some kind of spacer in the shock to reduce the amount of droop in the rear? Where exactly would you put the spacer and any idea on what to use for a spacer ??
THANKS
Ralph289 is offline
Old 03-14-2012 | 07:45 AM
  #815
ovalracer1m's Avatar
THANKS
Need to install the spacers on the shock shaft below the piston. This will limit total downtravel.
ovalracer1m is offline
Old 03-14-2012 | 08:06 AM
  #816
Ralph289's Avatar
Between the piston and where all the seals are ??
Any idea what to use ? how about some nitro fuel line??
Ralph289 is offline
Old 03-14-2012 | 08:11 AM
  #817
Buy a pack of limiters for $2.00. AE sells limiters specifically for that purpose. To answer you question, yes, the limiters go in between the piston and the seals on the interior of the shock body.
Hinecken is offline
Old 03-14-2012 | 08:39 AM
  #818
Ralph289's Avatar
THANKS for the info.
Ralph289 is offline
Old 03-14-2012 | 09:00 AM
  #819
Cain's Avatar
Tech Legend
if you want to see how the effect of limiting the droop would be, I have heard you could run zip ties to limit the travel and then based on what you find, you can make it more permanent by putting limiters in the shocks themselves.
Cain is offline
Old 03-14-2012 | 09:14 AM
  #820
Joyridn's Avatar
Very useful thread, thanks for all of the good set up tips. I do have one question, for the guys running high traction indoor clay... what camber front and rear angle are you finding to work the best?
Joyridn is offline
Old 03-14-2012 | 09:21 AM
  #821
-1/2 t0 -1 all the way around
frankrizzo is offline
Old 03-14-2012 | 09:38 AM
  #822
DaveW's Avatar
Well poop. Ok i thought the new tower had the 4th in it. I guess i misunderstood a previous post. Thanx for the feedback.
Thats what i did was used a spare tower as a jig. The holes are in line with the others, and spaced the same. It just looks a little close to the top of the tower and the plastic looks thin. It held up fine this past weekend though, it just feels like i need to add another downtravel limiter (currently 2)...
DaveW is offline
Old 03-14-2012 | 11:40 AM
  #823
Jake S's Avatar
yeah only the buggy got the "added" 4th hole from the factory. wish they would do it to the truck too, since its the same tower on the sc10 and t4.1 now
Jake S is offline
Old 03-14-2012 | 06:46 PM
  #824
Drtdvl5's Avatar
Does anyone know the bearing sizes that are in the stock rtr 4.1 wheels and also the ones in the rear hub carriers? Are there better bearing available that are more sealed? I've gone thru quite a few bearings in the hubs and in wheels..besides the fact they need to be balanced..which is another question..
Thanks guys
Drtdvl5 is offline
Old 03-14-2012 | 07:11 PM
  #825
Jake S's Avatar
http://www.amainhobbies.com/product_...el-bearings-10
3/16 x 3/8. in the wheels and the rear hubs in the t4.1 rtr with plastic hubs.
if your going through front wheel bearings sounds like your tightening down too much on the nut, and same in the rear.
Jake S is offline
