RC10T4.1 Thread.
Old 01-14-2013 | 07:39 AM
  #2791
Tradin Paint's Avatar
Originally Posted by trick25
for you guys that have the hex drive. does anyone know if the lost 22t wheels fit and have same offset?
yes, I believe they fit however the offset is way off. They cannot be used
Tradin Paint is offline
Old 01-14-2013 | 07:47 AM
  #2792
trick25's Avatar
thanks. im getting anxious about the t4.2 coming and collecting tires.
trick25 is offline
Old 01-14-2013 | 07:52 AM
  #2793
ilanstylz's Avatar
Ok seeing how the original poster on this thread never created the first thread to list all the information/hopups/how to's etc etc I am going to give someone a chance that wants to take control over the first thread and update with any/all information they can on the first two posts. Leave the first one for all the box stock information etc and the second post for all the mods/hopups etc you can do to the t4.1 to make it better. So if someone is willing to do so please pm me..... Thanks
ilanstylz is offline
Old 01-14-2013 | 03:18 PM
  #2794
CamZH's Avatar
Anyone ever had a ball stud break on one of these ?
Just took a t4.1 out for a maiden run over the weekend and sheared a bull stud on the hub tower, on the 1st pack...
CamZH is offline
Old 01-14-2013 | 05:50 PM
  #2795
YankeeFan123's Avatar
It happens, especially when I get sideways over a jump, its a lot harder than my buggy to correct it, but things happen..just gotta get a new hub tower..or move the location of your ball studs
YankeeFan123 is offline
Old 01-14-2013 | 05:51 PM
  #2796
Wildcat1971's Avatar
my kid broke another stud this weekend. I am going to try the sc10 4x4 camber link mod.
Wildcat1971 is offline
Old 01-14-2013 | 05:55 PM
  #2797
sunco1's Avatar
Can you use hex with a wider offset to compensate? I don't know whether the 22t wheels go to far in, or are to wide.
I run a 22t now but I wanna switch to a t4.2 when they come out. But i've got a whole lot of tires that I dont wanna have to get rid of
sunco1 is offline
Old 01-14-2013 | 06:16 PM
  #2798
That's a very good and durable upgrade but expensive if you ask me. Probably save money though if your kid keeps breaking them
  #2799
whats a good starting set up for a medium to highbite track standard bore shocks 17.5t motor
dezertranger96 is offline
Old 01-14-2013 | 06:17 PM
  #2800
ilanstylz's Avatar
Nobody??
Old 01-14-2013 | 06:18 PM
  #2801
it is only 14 dollars......and I can do the t4 and sc10 with it...
Old 01-14-2013 | 06:29 PM
  #2802
njnewc's Avatar
Wildcat what is the Mod with the 4X4 camber link...
njnewc is offline
Old 01-14-2013 | 06:38 PM
  #2803
Nobody??
id be interested if i had been in this thread for longer
  #2804
you replace the rear turnbuckles and ballcups with the sc10 4x4 link. They are onbay for $14 shipped for a set.
http://www.ebay.com/itm/400383996331...84.m1423.l2649
I "THINK" the 63mm rods will work. they are a little shorter than the T4 link, but the ends are longer I believe. For sure you can dremel down the long link and use it. I plan to use the 63mm links, so I can do my t4 and sc10 with those links for $14.
Old 01-14-2013 | 06:43 PM
  #2805
Ian most of the information is the same. u-brace C-hubs, etc. The hexes conversion and 4hole would need to be documented. I can probably do it and resuse the content from the b4.1 thread.
