Carpet Off-road Thread
#811
Yes there fine for several sets of tires. I usually run mine through 3 sets. Don't trim them or do anything else just run them the way they come from the package. Once the tire is gone carfully cut the tire open and pull out the insert, mark it with a sharpie to keep track of how many times its been used then throw the rim in acetone to remove what's left of the tire.
#812
Got my SC10 halfway decent on ozite at my local track, still have issues with it going up on two side wheels on occasion. Will gluing only the front outer sidewalls help this, or does gluing all 4 have a better effect? Already lowered it, upgraded my springs to red front and silver rear, 40wt all around, and stood up the shocks by 1 hole from the base setup and saw dramatic improvements there. Running jconcepts Swaggers up front and pindowns in the rear. Thanks!
#813
Tech Legend
So we have been running astro here for a few weeks. Going back and forth on tires and so far I am finding I am liking the feel of the jconcepts tires for our conditions better than the schumachers I got in here, the stagger or whatever its called 4wd front (premounts) and the cactus rears, yellow compound. They feel too grippy.
I was wondering if maybe trying a blue compound was worth a shot? Jconcepts pin downs feels just right using a common astro setup on my buggy used in UK with there mini dart tires.
#814
#816
the ball studs on the front front and rear shock towers.Remove those washers.it will help some to keep it more flat in turns.Less body roll.I lowered mine but have not got the chance to run it.Going to track tomorrow to see how it feels.I also trimmed one outer row of pins off on rear.im running prism rear z3 and z3 wedge up front.Not sure where your running your battery but nearest to the front of the tray would be a good start and keep the toe front and rear 0-1 degree neg.Good luck
#817
Negative rear toe? Most trucks I've seen have been negative front and positive rear. Negative front helps with turn in and straight stability, positive rear helps with mid apex speed and braking stability. Just making sure we're on the same page there.
Thanks for the tip on the ball studs, I'll try that as my next mod, followed by electrical tape for a temporary tire mod before taking out the dremel
#818
#819
Tires winter 2019
Can anyone confirm that using narrow front rims is still the ticket? I see Wedges selling in typical front width now. Going on a b6.1.
Are mini pins still the ticket out back? I see cactus and other tires that aren’t minipin \ pinpoint. For office type carpet, very high grip.
#820
On very high grip, slim cut stagger and cactus rear are the ticket on my b6.1
#821
#822
Curious if anyone has any general tips for those carpet tracks that don't allow pinned tires? At our local track octagons in gold compound seem to be the tire of choice followed by proline primes. It seems the tricky thing with these tracks is that the high traction of pinned tires isn't available, so it requires a very different car setup to what is typically run on carpet...
#823
Tech Legend
conditions can be seen here:
#824
That's gonna depend on how much traction there is with slicks(or nearly slicks). Usually with a carpet/turf setup where pins are used, I find myself taking out as much traction as I can and trying to keep the car as flat as possible. I've run on CRC carpet with sauced slicks that was like velcro.....pretty much ran the same setup as turf/carpet. It really depends on what you want out of the car and what kind of feel you're after.
#825
Same here. I have a set of slim cut staggers that I put some cut down Schumacher foam in as well. Very predictable push on power and off-power steering is just like the same tires with no foam. No sauce on very high grip carpet.
