Carpet Off-road Thread
#361
You don't glue the sidewall to the wheel at all, just the bead and the tire "floats" above it. Look closely at the pic of the premounts and you'll see what I mean.
Also, be sure you cut the width of your rim down by trimming the innermost channel off. So the bead is mounted against the second rib. You don't have to cut the wheel off as long as you mount the tire correctly, but I think it's much cleaner to go ahead and trim the wheel.
#362
Tech Legend
alright guys I am looking at some "cheap" options for tires here, I see a variety of older treaded tire types I can get new for about $7 or less shipped. things like ions, etc in clay compound. I figure as they wear, they basically become a slick anyway. Does that make sense? Are there some tread types if you go that route make more sense that others?
Also, in general are the schumacher staggers pretty much the way to go for buggy fronts on carpet? I know guy running them and they appear to work quite well.
#363
The D-boots square blocks with AKA red inserts work good up Front . D-Boots Terabytes same inserts are good work better with wear and sauce though .
Clay tires actually the Typos with wear and sauce work good even Chainlinks .
#364
I buy the narrow front Schu rims so I don't have to cut down a Proline rim.
The Schu setup is Super high grip. So much that very stiff springs and lowered ride heights are the norm. I went full retard on my B5ML spring rates and it's working well.
They never need to be cleaned or sauced if you only run them on carpet.
On grey Ozite, I actually like a brand new set of M4 Electrons all around and I can run my indoor clay setup, no sauce.
I race off-road on looped office carpet and 1/12th scale/WGT on Ozite. My testing with the B5M on Ozite was esc/motor tuning, but I was shocked at how well it actually worked. Went up 2 teeth on the pinion and left the on-road stuff on my pit table.
For the truley cheap SCT driver, I noticed that one of the cheapo pre-mount companies had Goosebumps pre-mounted for under $20 under a different name. I may have been Speedtreads Konekt, I can't remember. Should be amazing on office carpet.
#367
I forgot to mention the carpet i race on which is ozlite setup wise on my 2wd Buggy all i did was make the ride height at 20/21. Shock oil 32.5/32.5 Gray Fronts/White Rear although its actually a bit soft up Front still. Gear diff 5000k could go with 4000k though since its not high grip.
So not much change setup wise from running on clay other than ride height and a Ball diff/tires but the gear diff works on it.
#368
Super Moderator
Yes, Primes will DEFINITELY work, but I don't think you need to use M4's, I think MC's would be ideal. I did a tire test at a new Ozite track that's getting ready to open, & tried my 2WD buggy with my Primes, & I LOVED it, my buggy felt even better than my sedans did, but I did notice the M4 rears I tried took a real beating, I think they'd get chewed up pretty fast. But the MC tires had plenty of grip, & showed no significant wear, & with them I felt no need for traction compound at all. I think just a light cleaning will be plenty to keep them in good shape & MC's should last a good while. It's definitely what I intend to start with when the track's ready for their first race day....
#369
Super Moderator
#370
#371
I'm surprised a track owner with the brand new black Ozite allowed an off-road vehicle on it at all.
#372
Super Moderator
The grey Ozite and the new Black Ozite have completely different grip levels and wear. The new black version has milled rubber added to it when it's made. The grip comes up very fast compared to the old grey that took a month of heavily sauced 1/12th/ WGT racing to bring the grip up.
#373
Just curious, for those running slicks in the rear for 2wd, what fronts to do you use?
Slicks as well?
How about Schumacher Cut Stagger Low Profile? Will these work?
Slicks as well?
#374
Those Schumacher fronts are the front tire of choice about 95% of the time when slicks are not mandated but I can't see them not causing a imbalance/hook when used with slick rears.
