Need help Losi XXX-SCT RTR
#16
#17
Unless i missed it, did the OP even mention what esc he was using?
#18
If we are talking about the stock losi speedo you have to double pump the brakes to get it in reverse. (assuming it has reverse enabled check the manual on ESC settings to verify the mode the ESC is in). There should not be a dealy in hitting the throttle from dead stop. If you have not done it already it is always a good idea to rebind the radio and re set the end points on the ESC. All this is covered in the manual and it may solve your problems.
#19
#20
You should try it, tell us what they say. 877-504-0233 (option #4)
Don't forget to tell them the part about "Most times this is noticeable if I reverse it, then accelerate."
No need for any more tough guy talk, call them. BTW, your nickname fits you.
#22
Chill out. Someone asked a question. Some others answered. NoRookie went out of his way to call customer support for a guy that asked a question on web board. If you are not going to add anything constructive let the thread take it's course. This is not even your question?
#23
#24
#27
Who said you were right? You didn't have the stones enough to even call tech support yet, did you?
#28
#30
I agree I know were missing infoand i know everyone is trying to help but some are taking it too seriously. Relax.... were all here for the same reason
