Read before buying ProMatch Batteries
#31
i am using the 3 lipo's in question this after noon i can prove this again guys i know how to use my charger
they dont go close to 6200MAH simple
i will even use a different charger to prove the point once i run them out this afternoon
#32
It may be the charger settings
I think the main issue may be with your charger... That charger I think comes with a default of 120 Min. as stated before and 5000 Mah cutoff. Often it can sit at a low amp rate and the voltage does not change much but it can sill put a few hundred Mah into the pack like that as it keeps the cells balanced as well. If it is not the charger, then I am very sorry, just trying to help out.
Good Luck.
#34
I think it's sad you had to bring this to RCtech and drag a good company through the mud.....if I was dealing with you I wouldn't email you back either, sounds like nothing will make you happy. You're that guy who buys a motor...over gears it, over heats it and calls it junk and when it doesn't work properly.....you whine and request a refund.
#35
Hello,
Good Luck.
Good Luck.
this may be the issue..I know my charger has a 5k mah limit and I have a couple of 6k batts. so I have to restart them after they take 5k mah put back in..check to see if that is in fact your issues guys if you haven't already.
#36
R/C Tech Elite Member
ProMatch Good to me...
When they have the Batt. in stock shipped fast . The 6200 does not charge up to its 6200 but gives good performance even though its puffy. My shorty 4000 lipo is flawless. I give them 2 thimbs up but do think a phone # is in order. at least to leave a mesage! When there was a extra Batt. lead left out of my order they shipped it right out no questions asked!
#37
As an aside, Promatch and any other battery company is at the mercy of the battery manufacturers. Anybody remember the IBC 4200's? Great batteries initially, but the high self discharge rate crapped them out quickly.
#38
#42
Just like Maxamps and other overpriced shite
Cheap but really good most likely one of the very best: Gens Ace (does better then most brands that cost triple the money)
Cheap and alright : Hobbykings stuff
#44
Its the truth and more and more proof comes all the time.
People who still swear by stuff like maxamps are just morons with a thick wallet mostly Really sorry to put it like this but has to be done
#45
They were 'the way to go' until everybody noticed their cells had less lifespan than a butterfly and that they were super prone to puff and blow.
Plus the so called 'real 160C' were so made up that even Turnigy Nanotech 50C batteries blew them to the dust at 1/6 the cost per mAh.
Who races Maxamps now? No one
