Traxxas Stampede Forum
#766
Vato, which gears do you strip the most? I'm also running mamba 5700 in my pede, but I'm running it with 6 cells and I haven't stripped anything yet. I find it has enough punch with 6 cells, it can do wheelie easily also. My motor actually gets pretty warm after running through a few packs. I'm using 87t spur and 15t pinion. Any idea what's the smallest pinion I can put on a pede?
#767
if you get the wide pede conversion, do you need extended axles too?
#768
have you tried running a smaller spur and bigger pinion? that will make it faster and keep the wheels on the ground better
#769
I have not tried running bigger pinion, I run it on my local track which has lots of turns. I rarely ever use full throttle on the track, it's hard to even to keep it going straight. I guess gearing it up will keep it from pulling wheelies, but so will loosening the slipper. And the motor is running pretty warm, gearing it up will probably make it hotter and reduce my run time.
Also I have wheelie bar, which helps the preventing the transmission case from being teared up and adds some weight for more traction.
#770
Also I just pulled open the whole rear end since I thought the diff felt a little weird which made the truck harder to controls. Turns out one side of the wheel has bearings and the other side has bushings (I got the truck used). After my rpm carriers/bearings come, I'll see how much better it handles.
#771
#772
if it gets warm already then yes it might ruin run time. but if it stays below thermal temps it wont make that much a difference will it?
#774
main diff! my bad.....
#775
they are just different names for each other i think. hey vato do you think the rsuty gear box could take a 7700 mamba? i really want to put one in my DI. that would be sick.
#776
#777
yeah all ive done is drill holes to mount it. no trimming or anything.
#778
Got a question do yall think its safe to plasic dip an esc for water proofing.... And what could I use to shield my motor from water..... I know on the rc bros site they show plasti-dip used for the steering servo, recievers, and throttle recivers,,, so what about escs?
#779
quick tip........ DONT DRIVE IN RAIN. if its wet, avoid the puddles. a little water wont kill a motor, but keep it dry. thast the best way. does your complex have a parking garage? those are awsome places to drive pedes. i know with mine, i will go as fast as possible, slam the brakes and turn, the nget hard on the gas again and do huge spins for like 50 feet. haha
#780
i wouldnt recomend somethign that has constant currents going through it and constantly heating up and being used. steering servos dont get hot. esc's do. plus if somethign seeps in and blacks the tiniest current, its done for.
