TLR 22T Thread
#3362
Some on board of the 22T at the race last weekend. Went on to take second in the A main.
Link for the IPhone guys
+ YouTube Video | |
#3363
You have two tries to make a Loose nuts race. The electic series on June 9th and the MN series the weekend after. I am putting the cam on the very fast Kendall Welch's car for the electric race.
#3364
I have an issue with my thrust bearing screws breaking. how tight should the thrust bearing screw be? I run a stock motor so i tighten the slipper to the point where i get very little slip. I've broken two already. I've heard they should be tightened so that when the rear wheels are spun in opposite directions, they should rotate one and a half turns. Is this true.
Ive just installed AE thrust bearing screw, i heard they were better quality. Before i tighten everything down, i thought id seek confirmation on how tight they should be.
#3365
R/C Tech Elite Member
#3366
22t help!
Ok i have a 22tquestion that is still pretty new but am having issues with it not steering to the right at times. First i thought it was the servo so i put a new sc1256tg savox in it and it is still having issues to the right. Ive checked for binding and its not, im at a loss of how to fix this. Its my wifes truck and we have a race tomarrow and really want to find a fix by tomarrow.
#3367
If the servo horn stripped?
#3368
I checked the servo horn when i changed the servo wednesday, was like new still. Ive never had a problem like this, starting to think this rack steering is a stupid idea. Ive had alot of r/c trucks and have never had a problem like this. Turns great to the left but only has issues to the right.
#3369
is it shimmed properly, i.e. is the horn hitting when turning right. Had that issue in my 22 buggy just wasn't shimmed just right and made contact when turning to the right.
#3370
Yeah its shimmed up right dont seem to be hitting any where
#3371
is it close to centered with out using a bunch of trim? Thats all I can really think that would be left.
#3372
epa in your controller?
#3374
Ive tryed different rx tx, and it only happens now and again, also using a glitch buster
#3375
Using a viper vtx10 esc and everything is new, have dx3e and sr300 rec. Tryed my dx3s and 3300t rec, nothing has fixxed the issue.
