TLR 22T Thread
#2866
I broke the body mount clip on my truck... part number is tlr1102. It looks like u can't just order the mount, u have to order though whole shock tower, is this true? Also I want my truck to me quicker, do I have to go up or down in the pinion gear?
#2868
What about the body mount clip holder any ideas?
#2869
Would putting a gear diff in my 22t be worth it?
#2870
I think so...im in the process but its rainin so no testie....losi's always had the worst ball diffs and always will....im usin sc10 gear w/shims and outdrive mod to eliminate the small amount slop they usually have in em...but that slop is also bind which =traction also....we'll c when it stops rainin
#2872
I did it
I just recently bought the kit and built it up with the intention of using the gear diff. I have had bad luck with the ball diff on my 22 and I just did not want the hassle. I have had several packs through my truck now and I am happy with the gear diff. No issues or lack of performance. I am happy with it.
#2873
I think that you do have a point but I for one have followed the break in process and have even taken my time and gone a little longer to ensure that it was in fact breaking in properly, but to no avail. I have been consumed by this issue that I have been having and have researched and watched videos and everything. I did not want to possibly miss something. Nevertheless, I still have had bad luck and rebuilding it or redoing the diff only after one battery cycle is way too soon. I could not get the feeling of sandpaper to go away. It was not smooth at all.
#2874
I like my 22t i must say, but the more parts from other brands i use on it, the better it gets in all aspects! So losis will remain garbage but the 22t is a very positive and pretty sick rebirth of a fun ass class!
#2875
#2876
It's all about setup between slipper and diff screw. I have seen guys ask why there brand new diff feels gritty, only to find they have the diff screw snugged down.
I prefer the B-Fast unit for my ball diff, they are always butter smooth and last 10+ race days. (with break in)
But if you guys want to go to a hassle free gear diff and have less then Top notch performance. Go for it.
#2877
Batteries
Where can you buy cheap batteries for the 22??
#2878
depends, if you have the time in the world and "Experience" as those would say " No problem Here" type of guy then its not worth the peny, but if you have little time and would'nt want the hastle of thinkering with it every other race day then i think its very much worth it... I for one bougth the 22T for the purpose of using a gear Diff. Much consistent ( for me ) and doesnt requires that of a maintenance as compared to a Ball diff... just need the correct gear Oil though... its the leave it and forget it ... hahahah...
#2879
Seriously losi ball diffs have been awesome. Most of you guys bitchin are used to gear diffs in 1/8 scale cars. Associated diffs are just as good as losi. The quality of the balls are the issue. I actually built my 22t with a gear diff first. I used 5000 wt oil and the diff action was really free, which made my truck really rotate around the corner. I would try grease in it next time. I changed back to ball diff after trying the gear diff with 5000 wt. I used the stock balls,,, I know,,, thinkin they wouldnt last. Ive gotten 4 race days with them and they still feel good. And i didnt even break in the diff.. Im going to use ceramic balls next rebuild. Ive been using ceramic balls on my 22, and gotten at least 8 race days out of them without a rebuild. Still feels good. But i know it needs cleaned. Ive been building ball diffs for 20+ years, so i know what im talikn about!
#2880
