TLR 22T Thread
#2731
http://prolineracing.com/tires/the-e...k-front-tires/
w/
http://prolineracing.com/tires/subur...ck-rear-tires/
(w/ molded foams)
Think those would work good?
w/
(w/ molded foams)
#2732
I just got my truck built, used Dustin's setup.
I've never broken a rack in my buggy, but I broke 2 in the truck in a span of 15 minutes. I didn't hit anything, I just landed crossed up....
I ordered an aluminum rack to try and get some wheel time on this truck. Has anyone else run into this?
#2733
R/C Tech Elite Member
#2734
Some people think there was a bad run of racks, something with the plastic, but I'm not so sure. I think it is due to the wheel hitting the spindle and driving all of the force straight back to the rack. With no servo saver there is nothing to take up the shock, so the weak link breaks.
We ended up with an aluminum rack because no one had the plastic ones at the time. Haven't had a problem since.
#2735
Turnbuckle and ball end cups
I recently built up my 22t, much like most of us here, but have noticed a slight issue with the tight turnbuckles and ball ends. I made my adjustments of the turn buckles and installed them on the truck. However, when making tuning adjustments now, they are so tight that they pop off of the ball studs. Any suggestions on how to improve the adjustment process without the turnbuckles popping off all of the time?
#2736
green slime
for the turnbuckles take them appart and AE makes some stuff called Green slime put a little in the ball cup before you put it back together then hold the ball cup with a pair of pliars and run the tie rod all the way in. That way you will have threaded it all and it will adjust with ease and not keep poping off.
Jeremy
Jeremy
#2737
I just got a set of the std. aluminum 22 hexes that I am going to put on the front of my truck..... saw somewhere that one of the guys said this fixed his ball cup popping problem... figure i'll get ahead of the curve and try it myself.
#2738
#2739
I use either white or black diff grease on the threads, wichever I have more of. Much easier to adjust and assemble links.
#2740
#2743
@oilguy - I have yet to find a foam i am happy with for my 22T (rear tires mostly), I am gonna buy some AKA Truggy foams and trim them down to fit is my next plan.
Pro-line molded foams are simply terrible now, fall apart long before the tires wear out. Guess some bean counter there figured out people had been reusing the foams and had the lab monkeys make up a new formula that breaks down quickly.
#2744
#2745
Yeah the molded blue are the ones i am unhappy with, both in my DESC and my 22T the last couple sets of Pro-line blue foams have simply fallen apart long before the tires had worn out.
Going to try these in the rear, just need to trim them to fit-
http://www.amainhobbies.com/product_...-Insert-Soft-4
