RC10B4/T4 Forum
#1367
I've had my T4 since sept 05 & I think I have broken every part in the book!LOL. During the indoor carpet season I went through alot of a-arms, then ran in the winter nationals in Red Deer, Alberta & couldn't keep the car together. Now I'm racing at the outdoor track & have had very few broken parts. Maybe my driving is getting better!?
#1369
This is my first time posting in this thread so if anyone knows the answer please let me know or direct me to any posts that answers my questions. I bought a Checkpoint Money 19t and planning to run my T4 and give it a run or more. My question/s are the following:
What pinion should I use with 87t spur?
How tight must the slipper clutch be in terms of turning the wrench if you know what I'm talking about?
Any precaution/s that I should be aware of while running?
#1371
Alright its completely assembled... had some issues putting the shocks together, but smooth otherwise. Also outfitted everything with Deans plugs, threw on RPM ball cup ends throughout, and put on the batt tray thumb screws. I kept the plastic chassis on as recommended.
Notes on the kit:
-very nice how they put a 1:1 image of the screws needed in each step.
-hard to see which washer is which in the instructions (I had to back-trace them through the parts list a few times)
-fit and finish is nice on most of the parts
Notes on the kit:
#1372
OK... I was hoping to find a Novak GTB 6.5r for my T4, but nobody close to me has them in stock. My question: could I throw the 4.5r GTB in it and de-tune it with EPA's and such to make it controlable? or is it going to be a waste of money because its too powewrful?
Question #2: The other GTB I found close to me is the 7.5r... is this powerful enough?
I really dont know too much about b/l systems, but the 6.5r was the one recommended to me.
#1373
The 4.5 would be way to much motor for off-road. It could be detuned with epa adjustments, but I don't think you would like it.
The 7.5 would work, but it's about the equivalent of a 13T motor I think. So it's better suited to a buggy then truck. Either way, I don't think you would be disappointed with a 7.5. Don't forget, just because you buy the 7.5. You can go out later and get the 6.5 motor. (It's good to have a backup motor regardless of being brushed or brushless.
Paul
Paul
#1374
At the moment I am running a Reedy Flash rpm based 13 double and the power is ideal for my skill level, so if the 7.5r would be comparable then I may go that way. No hobby shops close to me seem to have a 6.5r in stock... only the 4.5r or the 7.5r.
#1375
Purchase the 7.5 system. You can go back and purchase the rotor for like $35 new if the 7.5 is not enough power.
#1376
Just FYI, but by purchasing a new rotor, you will not see any prformance change. Unlike brushed motors that have the windings on the rotor, brushless has it reversed. the can has the windings and the rotor has the magnets.
if you want to upgrade for more power, you must buy a new motor can...
#1377
thanks
#1379
hey does anyone know where i can find a good setup for my ft t4? i race int. stock truck at socal rc (low/med grip, bumpy, clay) thanks-Mike
#1380
Try the Tebo 2005 ROAR Nats Setup. If you need more steering try switching to Silver fronts.
