RC10B4/T4 Forum
I'm stocking up on parts for my ft t4 other then arms and bulkheads what else should I get
You should also get the body mount as those can break if you flip alot.
You might as well get one of each shock tower just in case but I hardly ever broke them.
If you dont want to worry about bulkheads then get the aluminum
whats everyone running for stock truck gearing?75-30? im runing tc spec with orion 30c with tekin 17.5
Trader Rating: 18 (100%+)
ally steering blocks wth. plastic all the way. i dont remember last time i broke a steering block, i dont ever remember breakin a steering block. usually a carrier goes if ur gonna kill somethin. no sense in spending $$$ and ur carrier will just break anyway. not to mention adding mass to end of suspension never helps.
R
R
nose dives
my t4.1 refuses to land jumps level or rear first. always hits the nose and flips. How do i fix this problem?
It's better to land slightly nose first rather than tail first, it gives you more control. Obviously a nose dive and flip is not good!
If throttle control just cannot get the nose up, try a slightly stiffer front end, or a slightly softer rear end, or limit the rear droop a little.
next question
My rear end was making gritty noises so I called AE. he said was the shims in the diff. apparently some shims were made to thin, but there was no way to tell if I had the correct shims or not. so they sent me some shims and told me to add them giving me 2 shims under the sun gear. My question is the pin that goes above the shim, Is that supposed to be very tight against the shim or whould there be a little wiggle room. I added the shim they sent but didnt seem to fix the noise in rear end and if the 2 shims arent correct then Ill remove the extra one. Soryy for the long confusing question just trying to quiet my rear end>
more info for above question
by the way this is a t4.1 with a gear diff obviously.
heres my FT B4. Haven't even had it on the track yet. Cant wait till i do though. It has a Novak Ballistic 7.5 motor and I think its a GTB esc I THINK. I'm very new to the 1/10 electric stuff. I've always raced 1/8 nitro buggys.
I can't get my shocks right. I get all the air bubbles out but when I put the cap on and tighten it, I can feel air bubbles forming in it and it feels like there isn't enough oil in them. What am I doing wrong? I filled them all the way to the top..
