RC10B4/T4 Forum
When the guys at SRS were helping me they kinda took it apart and I believe it looked ok. They tried new sensor wires same thing, put a different motor on the speed control and it did the same thing. So I sent it to LRP to have that problem fixed. I dont know what gives.
Maybe check all the solder connections. there could be a problem with the power capacitor or even a broken wire on the motor wires inside that you can't see. As for the gringing type noise, can you hear where it's coming from. If it did it with a different motor check the bearings in the rear hubs. I'v had a few bearings go out and there was some wabble but they were still free. Idk.
I will take a look. I am not the best at seeing what I am looking for but I will try. If I cant find anything I will take it to my LHS is Oregon. They will help me I am sure
take the motor out, roll it across the table and pick it up and see if the rear tires keep on spinning or if it makes the same noise
kinda gettin frustrated with my b4 seems no mater what i do i cant keep the rear planted in turns
What have you tried so far to increase rear grip ?
Have you tried the Racers Edge .5 degree rear hubs? They made a huge improvement on my B4. I would try simple first, like checking camber, an unglued tire, etc. Also check to make sure there are no broken parts, such as a cracked arm or rear hub. Hope this helps.
G'Day Guys,
This is probably a stupid question, but does the new shock rebuild kit fit the old shock bodies?
Smokey
Smokey
The new rebuild kits do fit the old shock bodies, are supposed to assemble a little better.
how does 1 differentiate the new rebuilds from old. and new shocks from old. lil late in the game here but i've been runnin a xxx for last 2mths.
i am usually shavin .3mm off my big spacers so that the stack matches the recess in the shock body itself. is this issue being worked out in new kits perhaps?
could try movin rear shock out on arm to sure up rearend.
R
R
R/C Tech Elite Member
Here you go R
Do you have the 'new' shock rebuild kits?? I have put the new rebuild kit in many of the 'bad' shock bodies and have yet to see one blow out.
Obviously the new body and new clips are the way to go, however just the clips alone should be fine.
The new clips have 1,2,3, or 4 very small dots on the square retainer clip. These dots should be located on the edge opposite the side of the slotted side. These dots indicate which mold they were made from, along with indicating that they are from the new molds, rather than the molds from the late 80's
I don't think AE considers that an issue. It is intended to compress the o-rings slightly. Losi's cartridges do the same thing.
I tried those hubs but Im having trouble with the wheels binding...I tried ir without the crush tubes and still rough...
