RC10B4/T4 Forum
#8761
Does anyone know where I can find a part number for the B4 1/2 degree rear hubs the team was running at CRCRC? Also, for the people running the new 4th shocking mounting hole, are you still cutting 1 & 1/2 coils off the black springs. Someone told me they were doing that.
#8762
So what size Lipo's are your guys running these days? Just getting back into off-road. I use my SMC 5200 40c's in on-road but thought it might be overkill in stock. lol. ANy suggestions to keep the dollar down but have the unff to kick but still.
I was thinking of getting some SMC 4500mah 28C SportMAX 7.4V Lipo's cause there only $65 ea online.
Will a 3200mah 40c last 6 min heats?
#8763
True, you may only use 1200 with a 13.5 but if you are running stock or even super stock you will want a good battery, because it means the most there. You will want every bit of batt you can get.
so, vr6cj, i would use your on road batts if you are running stock. They will hold better voltage than the 3200's
#8764
#8765
Some big on-road races have been won by 24C Sport packs for this very reason. So don't hesitate to run the lower C packs in Spec racing. You'll be pleasantly surprised with the results. Save the more expensive packs for your mod motor classes, because that is where they really shine.
Just food for thought.
#8766
^^ Oh no. Here we go. Someone who actually knows what he's talking about.
Can you please leave these threads for people to keep pounding the "biggest, most expensive, newest, is best" routine. You know that's all most of the posts are good for.
I hope you haven't ACTUALLY tried any of this or compared results, that would go against most of what I read here
#8767
The lower (24 and 28) C packs can actually peform better in stock classes than some of the 40C packs. It has to do with the heat that is generated in the pack during a run. The higher C packs can handle the lower loads of Spec motors (17.5, 13.5) without breaking a sweat. The lower C packs actually break a sweat running the Spec motors and start to generate some heat in the pack. Heat in LiPO's has been proven to lower IR and increase voltage. Higher capacity and lower C rate are a good combo for stock racing. SMC SportMax packs are a good choice.
#8768
Thanks for all the replys. So I think I'll go with my first thought and get me some those higher mah sportpacks. BTW: I was thinking that the motors might generate to much heat with the high amp draw of the 40c's and I'm still running brushed in my T4. Still got alot brushed so why not use them.
We still have some racers here running brushed motors with LiPO.
#8770
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
It's not the batteries that create high amp draw, it's the motors. A 40c rating is how much amp draw a pack can handle, not how much amp draw it creates.
#8771
#8773
The motor doesn't know the difference between a 40c pack vs a 28c pack. We as drivers see the difference.
The higher C rating packs are able to keep up with the higher amp loads of the modified motors. This will give you more bottom end punch and more sustained speed throughout the run time of the pack.
#8775
But 6 washers is insane on the 0.71 shafts, really restricted travel - are you sure the setup wasn't for the .80 shafts from a B44?
