RC10B4/T4 Forum
#7936
Billy, just remove any flash surrounding the pin holes & personally I also smoothed the edge of the pin with a file or emery paper....
The caster block pins are suppose to fit tight for the best performance....
#7937
The tight fit is not good, although yet again you are the know it all.
If I remember right the pins are 1/8" so if the parts have are binding then I will use a 1/8" drill bit (made for use by hand, not a power tool). It takes off just a little bit of the plastic and in most cases everything works nice and free. A few years ago I never had an issue with parts binding, as everything just drooped right in, but AE's new parts seem to be just out of spec as the hinge pins holes are a little too tight.
However before you do that, you might want to also try to polish the shafts as the black coating tends to make things stick.
#7938
A tight fit on the caster block & pin is very important !!!!
Carbon
I don`t know it all , but almost ....
Maybe your confuse ?
As in blinding between the Caster block and arm`s ?
This is a easy fix just clean any flash from the pin holes on the arms & caster blocks.....
Enlarging the pin holes with a reamer will only hurt performance....
On the old rc-10 B-2 & B-3 a reamer was needed & used , but with the B-4 those days are long past....
Ps
Please don`t polish the black off the pins !
If you do the pin will be smaller & slop will prevail.
Best to replace the pins after the black has been worn away to get a slop free& smooth fit....
Carbon
Ps
#7940
Thanks Wild Cherry and carbon madness, I got your points. I will try both your suggestions. I will try polishing the pin and edge of the hole first, and if that doesn't work, I will try the drill bit approach.
#7942
Billy , only smooth the edge of the pin , do not remove the pins black coating....
The caster block needs to fit the pin tight & yet move freely when mounted on the arm...
#7949
