RC10B4/T4 Forum
#7111
And I have tried more weight and is why I run .5 oz of extra weight. NOT 2 becuase 2 IS too much. Heck, thats 8 squares of associated lead....not sure you can even fit that much up there.
Product for adding .75 oz to the front:
http://www.redrc.net/2008/12/ghea-b4...-element-scab/
#7112
Must not of tried cus you still believe you gained steering , just stick on the nose between the tower on your body...
Trust me ....
or even better Big Head ....
Trust me ....
#7113
I have gone up to 1.5 oz and adding that much was detrimental and is exactly why I said adding 2 oz is bad. I also said that is why I add only .5 oz. Going back to my example of "too much camber": some weight can help especially on high traction tracks and too much will hurt. Saying that 2 oz was bad, thus any additional weight is bad doesn't follow.
#7114
Again just try , I been all though this before more than once ....
2 oz is not "bad" and is not gona "hurt" anything if you are trying to remove a whole lot of steering into the turns ..
This is all you will experience if you try...
Then take all of the weight off and see how much steering you gain back ....
#7115
My opinion for what it's not worth I found when you add weight to the front bulkhead you lose what I call "cut in" but, the car stays in the corner alot longer. So basically less steering in and more mid and exit steering. Picture 1000lbs sitting on the hood of your real car and going 50mph then you decide to crack the wheel hard left. That forward energy needs to be changed and will take more time. At the end of a long straightaway your car is basically still heading for the outside wall.
#7116
Thanks guys ill try the aluminum hinge pin brace and see how that works out. If i keep breaking then ill try the aluminum bulkhead.
#7117
You keep saying that braking (corner entry) transfers weight to the front and you gain steering, and then you say adding weight to the front looses corner entry. Weight on the front tires, no matter added or transferred, will result in more traction. It is about % of weight front to rear and that is why sliding the pack forward gains steering (on and off power) because the front tires how have a greater % of the cars weight.
You need to think as added weight and transfered weight as two entirely different things. While in the end they are 'weight on the front tires' they have the ability to work against each other.
The heavier the nose becomes with added weight, the more lazy it will feel entering the corner, because of this the car is less responsive. Your initial steering is reduced at this point.
The cause of this is that the weight bias of the car has been shifted more toward the nose of the car when weight is added. This gives less weight bias to the rear of the car. With less bias in the rear of the car, the car has less weight to transfer to the nose. Due to the car having less weight to transfer, it has less of an effect on collapsing your suspension to get the car to carve into the corner.
Once you get past the initial part of the steering and the weight has been transfered onto the nose this is where the weight starts to give more steering because then it is harder for the car to lift the nose. The car now has to work harder to lift the extra weight. Since it has extra weight to lift it cannot transfer the weight as easily to the rear, in turn giving you more steering exiting the corner from the weight staying on the nose longer. This can also make the car feel more lazy exiting the corner.
#7118
#7119
I am planning to use my LRP Sphere TC ESC in my new B4 buggy and I would like to know if it is advisable to remove the fan for off road buggy. Or it is ok to leave the fan on the ESC as it is.
Thanks.
Thanks.
#7121
Note you could also use drag brake to compensate if you do not want more weight, but this will make your car more twitch on the straights. To much drag brake will make your car/truck much harder to drive
Also to much weight can cause bad performance.
#7122
#7124
4wd would be the only one that may need the fan (definitly use the heat sink in 4wd though).
I test my vehicles without fans on the ESC but, if the environment you are running in is very hot (summer in AZ) you may need one. Also the amount of time you are running for will have an influence on the heat.
#7125
