RC10B4/T4 Forum
#6061
jcon = J Concepts
RPM makes a good camber gauge, and it won't take a big dent out of your RC funds. Also at times if your wheels camber is off the car can handle differnt form left to right, so it will help make the feel of the car a little more balanced with the way it handles (although there are other things that will effect that as well, but having the cars camber and toe the same it will help a lot with in the turn traction, and stright line tracking)
#6063
Help Please
I'm not new to racing but have just got back into it after 5 years. I am going the off-road route this time and have recently purchased a B4 and a GTB with a Novak 10.5. I have just finished putting it together and after installing the motor and esc and testing it it seems there is too much breaking once going to nuetral. I have been playing wih the drag brake settings but does not seem to help.
What am I missing where did I go wrong? please help
#6065
Jeff
Make sure you have program the ESC correctly and after your done go to throttle EPA on the transmitter and reduce the brake EPA until you are happy with .
#6066
Are you positive you have adjusted the right brake setting on the esc?
I have a GTB in my b4 and had to add neutral brake to mine, so i would make sure you set it up correctly and make sure your gear mesh is good.
#6068
#6071
#6072
Flip the sheet back over (pg.5) and it describes how to adjust the minimum and drag brake on the left
#6075
with the stock 84 spur, i would guess at starting at a 25 to be on the safe side.
Im running a 32/78 with my 13.5 novak, on a small med. traction clay track and not breaking a sweat like 130 at the most.
