RC10B4/T4 Forum
#4773
Are the o-rings the same? Whats TRF?
#4775
Wouldn't doubt you could buy a box of about 50 of the exact same thing from McMaster-Carr for a fraction of the price, too.
#4777
Thanks guy. I have an open account at McMaster Carr. Thats were I bought my lead for my LIPO.
#4778
I have had some A/E shocks that are not machined correctly and the clip pops out no matter what you do. Most of the team guys tell me when one ejects a clip, they change out that shock body.
I give it two tries since I pay for mine, lol, but if they pop out twice, I know I built them right, new shock body.
I mostly hate sitting there wittling down the edges of the spacers, etc. But, something I find alot of racers don't know is that the edges of all the spacers are different on each end. One end is sharp, one is rounded. Always install rounded edge first. Cuts less seals that way, .
...Jim
W.E.D.
...Jim
W.E.D.
#4779
I have bought a bag of 100 silicone orange o-rings in the specified 1/8 x 1/16 size from McMaster Carr --it was only like $5 for the bag. The problem is, they are very slightly larger with a tighter ID--they cause quite a bit more stiction on 1/8" Associated and Losi shafts. You can tell just by looking at them --its only a fraction larger but its enough to affect shock movement. Just warning others.
#4780
I have some on road TRF shocks and they are truly amazing. They might be so smooth because they only use 1 'O' ring and not 2. I considered installing the 'O' rings in my AE shocks and I recall comparing the two and deciding that they would not fit. But, I cant remember if they were too big or what I thought the problem would be - its been a while.
#4782
The Tamiya shocks use exotic hard coatings on the shock bodies and shafts, and even the pistons, plastic guides, are made of some strange slippery type of plastic. I'm not sure if its the flourine stuff they like to put on ball studs, but after using them in both onroad and offroad, I can say the are the finest engineered shocks you can buy.
Honetly I dont think the Tamiya silicone o-rings will fit. They only use 1 per body, and they are larger than the normal o-ring.
Doesn't General silicones still make R/C stuff? They use to make pure silicone o-rings for all the major shocks as an upgrade.
#4783
you can ream out the bottom of the shock where the o-rings go in with a .256 reamer, go slow. it will remove enough material so when the o-rings swell up they are perfect. however the o-rings may leak just a little until they do swell up and if you go too fast with the reamer, ie a drill, all bets are off because you probably ruined the shock bodies.
#4784
https://www.ssl-stormerhobbies.com/c...=ns&pn=MIP1043
These will work, but doesnt say what they are made out of. According to Tower AE seals are 1/8 x 1/4, or 3mm x 6mm, so it shouldnt be hard to find a pure silicone seal (if the size is correct)
#4785
The tamiya o-rings I am familiar with are the metric orange silicone ones we use in the 501x WCE shocks--are you guys talking about a different Tamiya o-ring?
Did anyone ever try fitting the blue Traxxas X-ring seals? Since they have an X-cross section they should seal quite well while still being very low drag. I don't know, however if the Traxxas shafts are SAE or metric.
