RC10B4/T4 Forum
#3766
Hello guys!!
I've been running my freshly built FT T4 for 3-4 packs and WOW what a change with 2WD!!
I really had a hard time on the very first 2 runs, now my slipper is looser and the diff also, I've dialed the ATL down on the radio
I didnt think 2WD such a different world, the driving is totaly different and I was so used to 4WD
I now understand why people say 2WD is more prestigious and a VERY good learning way to drive off-road!
Now, can someone tell me how you check if your diff isnt slipping? You want it very loose but cant tell if mine is ok??
If its like the rear of my B44, is it ok?
thx!!!
thx!!!
#3767
thanks scott!
If I twist one of the wheels the other one turns revs about twice
Does that make any sense or souds right??
I will test it like you described it, not sure to be able to notice the diffrence in sound betwenn diff/slipper, I mean when running outdoors or on track
So your method will be helpfull?thx!
#3768
1st. Remove the dust/gear cover.
2nd. Hold the right rear tire and the spur gear at the same time.
3rd. Turn the left hand rear tire.
4th. See that slipper will slip and not the diff. If the slipper is to tight you will need to loosen. Once you get to that point,,, which you will need to be at to protect the diff from premature wear you can adjust the slipper to traction availability.
#3769
HEY!!
HERES A VIDEO OF MY T4:
http://youtube.com/watch?v=N4zpdOTHRFY
AND CM367700's B4:
http://youtube.com/watch?v=wOFKxFU9xZg
PLEASE RATE AND COMMENT!!
AND CM367700's B4:
#3771
do as the manual suggests... tighten completely, the diff, then back the screw out 1/8th to 1/4 of a turn. Tune the car to the diff set like this, Don't tune the diff to the car, keep the diff consistent, never let the diff bark or it will score your diff rings. Don't overtighten (I've done this once) and snap the screw. It's best to use just two fingers because the torque from a full grip might snap it.
To adjust the slipper properly, hold both rear tires down, finger the throttle on the Transmitter in the left hand by putting the base of your transmitter on the left tire. See what kind of wheelie it does. If no wheelie = tighten, if higher than one inch = loosen, a one inch wheelie is dialed and what you are trying to achieve. The first few wheelies are going to be inconsistent because the pads are cold. Finger it a couple of times then judge wheelie height. Keep this tuning process as short and sweet as possible. You might burn your pads, I smelled mine after first figuring out how to do this trick.
#3775
hi guys!
Trying to setup my slipper correctly on my T4!
How many threads do you have sticking out the nut on the slipper axle for HIGH traction surface??
Running a 11x2 geared 87/18, FDR:12.56
THX!!!
THX!!!
#3776
Wait, holdup a second. Did anyone see Maifields vehicles. He added weight to the battery brace!!! Weren't some guys worried about raising the CG if they added weight up that high. I guess it isn't that big of a deal after all. If it works for Maifield, it works for everyone else right?
#3778
Here are Cav's wheels:
http://www.jconcepts.net/store/index...0113bdf0d9d154
They come in fours that's why the price is high.
#3779
#3780
