RC10B4/T4 Forum
#2933
for the 7.5 it feels best to me in the truck at 87/22 but the temps get up in the 150-range, and my batteries seem to get pretty warm after the race, at 87/20 the motor runs a cool 130-ish, and the batteries are much cooler, but the speed control goes up 15-deg (no biggie, still only 115) doesn't loose much top end, and gains gobs of torque.
think im going to end up running a 6.5 in the truck tho....thinking 87/18 with the 6.5 in the truck, and prob like 81/22 in the buggy for the 7.5.
drove this kids gt2 tonight (guessing he just wanted me to set it up, so i got to race it all night, did get it down, and he loves the setup) and set Tq, i think i like GT, hah....definitely has me thinking about the 6.5 in the truck...hah
#2934
I've been running my 7.5 with a 20 on it also. I like a 19 but the 20 was better laptimes.
The 6.5 is the most gas truck-ish feeling motor I've ran. I liked it but went with the slower motor for ease of driving. Probably switch to the 6.5 again b/c I miss the feel of it.
#2936
I believe I ran a 20 most the time. It was crazy fast top end but it made takeoff easier. I often limited the throttle epa b/c full trigger was rarely needed where I raced most.
But like you were saying I played anywhere from 18-20. I like a 19 on the 7.5 but it needed more top end to keep up. I run older 3800 batt's so my gearing might be a little off from what others are liking.
I believe my the motor stayed cooler when I ran the 6.5 compared to the 7.5
Probably becuase I didn't need to drive around full punched everywhere. Neither my 6.5 or 7.5 has the sintered rotor either.
#2938
.5 degree rear hub carriers
Does anyone know what effect running the optional .5 degree rear hub carriers has on the B4 - does it increase traction, cornering, etc.
(This may have been discussed before, so apologies if it has)
#2940
If you're talking about the LRP 6.5 turn, I run it 16-87 in truck with the std rotor. In the B4 I use 7.5 with 20-84.
Once you go up to a sintered rotor you gain a lot of torque and you can get up closer to 19-87 in truck with a 6.5. For the 7.5 sintered in buggy I would run 24-81.
I don't know much about the Novak stuff on how to gear it....
