RC10B4/T4 Forum
#1696
Originally Posted by WheelNut
The T4 is hands down a way better basher than the B4. The T4 has more ground clearance and suspension travel, so it will take a lot bigger bumps and jumps. The B4 just gets stuck constantly, and it sucks in grass.
#1697
If you won't be racing go lipo. By far the most run time. Especially with the efficiency of a brushless system.
If you want to occasionally race I would still suggest brushless and lipo. Just get an ESC capable of accepting all combinations. The new LRP's do this. When bashing use the lipos, and when you get to a race drop in NiMhs and you are legal.
To take it a step further, get a good brushed stock motor. Again the LRP will run brushed or brushless. This way if you don't want to run mod races you can put in the brushed motor with your NiMhs and you are ready to go.
#1698
Am I correct in thinking that brushless would be faster than nitro?
#1699
Off the top of my head:
Front arms
Front Shock Tower
Front Shocks
Front Springs
Front turnbuckles
Steering turnbuckles
Rear arms
Rear CVD or bones
Rear shock tower
Rear shocks (springs the same)
Rear turnbuckles
Chassis
MIKE
Front arms
Front Shock Tower
Front Shocks
Front Springs
Front turnbuckles
Rear arms
Rear CVD or bones
Rear shock tower
Rear turnbuckles
Chassis
MIKE
Originally Posted by sean
What are the actual differences between the T4 truck and B4 buggy? It looks like they are essentially the same with the truck having longer/wider A arms & suspension.
Is the conversion easy if one wanted to go back and forth?
#1700
Stuff that's the same.........Tranny/slipper/motor plate, caster blocks, spindles (but not axles), rear hubs, rear suspension mounts and bumper, front bulkhead and steering linkage.
Not practical to swap stuff.
#1701
Thanks guys, I appreciate it. It looks like T4 Brushless is the way to go. Nitro might be faster but everytime I get into nitro I immediately get sick of cleaning up all the "nitro slime", its bad enough that I have to do with my plane.
So... I guess I will have a go with brushless systems. Could be interesting.
Do you guys run brushless in your T4's?
#1702
I race both a gt and T4 with a brushless. Love the brushless, only way to go in my opinion, especially if you're bashing. Electric is as fast as the number of cells you throw on it. It can be faster than nitro. I run the novak gtb and 6.5 in my T4 and it is plenty fast for me.
#1703
What other brushless\esc combos would you recomend?
#1704
The new Castle Creations system looks pretty solid. I wouldn't go with any faster a unit than the 5700kv model. I have seen the 7700kv model in a stadium truck and it is not controllable at 100% settings even on a high grip surface. I have had great luck with the GTB 6.5 but I am looking to motor down to the 7.5 now that I am running Lipo.
#1705
#1706
can i equipt my rc10 t4 with te quickchane wheels from a gt2 ???????????????
#1708
Suspended
Wow, I have been out of the loop for a while. Brushless motors can provide too much power? I guess they really are as fast as the amount of cells you use.
#1709
I'm pretty happy with my GTB/Velo 5.5 combo (although the ESC fan is cr*p, replaced with the Novak 25mm)
Mike
#1710
I'm a bit of a newb to B4 setup sheets and offroad setup sheets in general.
Looking at the sheet on AE's website - the Maifield/Thielke/Cavalieri setup. The front shocks say -.060 limiters and the rear say 0.030
Is this just putting a .030 limiter in the rear shock and two in the front? I'm confused as to why one is negative and one is not. If your adding limiters - their limiting travel and should both be negative, shouldn't they?
Also - what's meant by "2 washers w/ New Brace" in the rear? What new brace? Or is that some kind of prototype thing they are running?
