Traxxas 2wd Slash Thread
#1411
If you have the Kings head center diff mount get the 39 tooth or you will need to shim it up to clear the 41. I installed the 39 and love it. Much quieter.
#1412
I am totally blown away by the Pro4mance kit, it is blisteringly fast and yet still forgiving. "It just does what you want it to". Here is my solid red beast doing some work in A-main.
+ YouTube Video | |
#1413
Installed this in my SCTE and ran it tonight at a club race, and i have to say it was horrible! I set it up with 55/50 shock oil with yellow on front and front black springs on the rear. Any ideas on a rough/loose blown out track? Dont get me wrong the kit is very nice and I can feel the SCTE has a lot more speed in but my set-up is off!
#1414
#1415
For any of you guys that are running indoor clay...you have gotta try the Panther slicks!!
All i can say is OMG !!
I was running Barcodes gold and this is wayyyyyy better....also the wetter the track the better.
Just have to share.
Just have to share.
#1416
#1417
lots of loose dirt, Ive always ran gridirons on front and enduros on the rear and had great success at all the tracks I travel to. Temps last night got down into the upper 40s so maybe its just the shock oil. Im not a huge fan of running the front spring on the rear either!
#1419
I'm a little ashamed of myself but I bought one of the Pro2 30th anniversary trucks and paid a grip for it. Back in the day I very successfully raced a ProTrac slash and could hang with or beat a lot of guys with SC10s. Believe it or not the Slash is very forgiving on the track. Its biggest problems are weight and a general lack of sophistication. Maybe the changes will make it lighter and more nimble?
I'm now 100% devoted to all things Kyosho. However, when you look at the Pro2 it has the basic design that all the new trucks are moving to [including the new Kyosho platform]. I'm not expecting the Pro2 to be as good as my SCR-SPs but I actually think that it will be pretty close once I throw some Kyosho big bores on it. I haven't read a too much about the Pro2 but I hope it is lighter than a stock Slash....if not maybe I can run a shorty pack. Anyway, I just had to try it. I hope I don't regret it. In any event, in a couple of months it will be up for sale unless its its that good which I doubt. I'll post up my results in a couple of weeks when I start using it to run Mod SCT.
On a side note, what would a brand new set of 4 Power Stroke Shocks be worth?
#1421
[QUOTE=buchanan88;11611013]5/7/3 diff oils as metioned 55/50 shock oil and I just set it up to the mip setup sheet that comes with the kit.[/QUOT
Thats the problem. Dont use the set up that comes with the kit. Go here https://www.box.com/s/0f2d69b41d9bd54d618e and used Matts Toys for tots low bite set up. ALL OF IT! Not just oils and springs. EVERY SINGLE SETTING. Also do you have the green and matt discs on the top of the piston or underneith? The WORKING build order is from the bottom up its washer, piston, green disc, matt disc and nut.
Follow this set up to the detail and mount up gridirons and you will be impressed. Good luck!
#1422
[QUOTE=rcracenut;11611842]
Thanks!! Im using just the blue disc on top of the pistons.
#1424
Matted in color ...like off white.
There are 3 sets in a kit...green,blue and matted.
#1425
