Castle Momba Monster 1/8th Question
I just set up my Castle ESC and it seems that the full reverse has more power than full forward. I even tried using castle link for the set up setting reverse for 25% power and it still is more powerful in reverse.
Any help is appreciated.
I tried changing wires around, changing the settings on the transmitter. No matter what I did when I pulled the throttle back, the motor spun the tires to move the car forward at a lesser rate than when I pushed the throttle forward for reverse.
I think there is an issue with the Castle Link V3.4 computer set up. I found that if I set the reverse setting to 100% and the forward setting to 50%, the buggy runs properly and when I set it to the factory default the forward and reverse power settings were opposite of what the Castle Link were. It might be user error, I will call Castle tomorrow and talk with them.
Anyway, what a difference it was from the first time I took it to the track. The buggy took off and was flying around like I had hope it would.
Thanks for your input.
Called Castle today and got it straightened out. They were very helpful. I never really had it calibrated to begin with because my transmitter throttle mode was reversed. THEN I had to change any two of the motor wires.
You'll need to reverse the radio, and the esc,
