Tune With Camber Links >
Like Tree65Likes
Old 02-14-2013 | 01:36 PM
  #1201
bds81175's Avatar
Moderator
Yeah, my bad. I had it backwards. Geez, ease up on a fella!
bds81175 is offline
Old 02-14-2013 | 08:16 PM
  #1202
Sorry, I didn't have my morning coffee yet. I went back and toned it down a bit.
400units is offline
Old 02-14-2013 | 09:25 PM
  #1203
darcness's Avatar
Originally Posted by 400units
Try it and post your results please.
Will do. I agree on the rear toe, but I'm fixed at 3 degrees with my current suspension holders and hubs. I'd have to purchase some aftermarket hubs to get the toe any more. Plus I think 3 degrees is plenty to be honest. Most I'd want to go is 3.5 which can be done with the RB5 STRC rear hubs. I might get those as well as trying the front camber link.
darcness is offline
Old 02-16-2013 | 03:20 PM
  #1204
That's plenty of toe. You have to decide if you want to solve your setup issue by increasing the rear traction or reducing the front traction. Then make the appropriate changes.
400units is offline
Old 02-20-2013 | 08:49 AM
  #1205
MikeXray's Avatar
Originally Posted by darcness
I'm having trouble with my RB5 oversteering. The rear end just wants to violently break loose around tighter corners. That's really the only issue I'm having with it right now. Steering is good throughout the turn and forward traction is great. Here's how it's set up right now...
Front shocks more upright (out on the tower)
Rear shocks more inclined (in on the tower)
Front camber link long, higher on the tower
Rear camber link long, higher on the tower
Front camber 1 degree
Rear camber 2 degrees
The track I'm running on is a pretty smooth clay indoor track, but traction is lacking some days, especially after they water the track. I would classify the track as medium traction bordering on slippery. After reading the thread I'm thinking I should probably raise my roll center in the rear. That means taking my spacers out and LOWERING the link on the tower. That should make the rear end a bit more predictable and keep it from breaking loose so violently. It's good up to a point, but after that it rotates way too quickly.
Am I thinking correctly here? If I'm wrong please correct me and point out why.
Since you mention having trouble when the track is wet, are you running full pin tires? When the track is wet here full slicks work best, but if it gets dusty you need some pin.
MikeXray is offline
Old 02-20-2013 | 06:29 PM
  #1206
jlfx car audio's Avatar
Here is a question for the experts that linger this thread .
more chassis role =more traction given examples I've seen in this thread
Assuming traction is super high like on carpet on road racing more role is only good to a extent then car begins to traction roll.
OK now if u limit the chassis role to much it will traction roll.
Now that we r on a tight rope balancing beam hear is the question I have
With a low inner camber link mount ( high roll center ) the tire keeps a more negative to strait up profile wile a side load is applied thru a turn , in my eyes the more contact the center of a tire keeps with the track the more traction it has available for the tire .
OK if u run a high inner link ( low roll center ) the tire is more actively changing Camber as a side load is applied thru the turn meaning the Camber goes in the positives (leaning out ) making the contact patch transfer to only the outer area of the tire . How does this promote more grip?
jlfx car audio is offline
Old 02-20-2013 | 09:34 PM
  #1207
darcness's Avatar
I also have a question for the guys who are a bit more advanced in this thread/theory we have going on.
I'm looking to gain more off power steering, especially on turn-in. My on power steering is just fine and my mid to late corner steering is acceptable, but turning in off power I plow like a dump truck.
Will spacing my front camber links higher on the tower side help me with this? The link is already as long as it can get, and the shocks are stood up pretty good (out on the tower, out on the arm). Just looking to really fine tune my setup at this point. Everything else is working beautifully.
Edit: Almost forgot, what about caster? Right now I'm running 30 degrees. Would changing to 25 degrees help?
darcness is offline
Old 02-20-2013 | 09:50 PM
  #1208
I've never experience more grip with positive camber. At that point I believe its gone past the point of being useful...I used to use positive camber in the front to kill the twitchiness in the steering.
If you are traction rolling with positive camber there may be other things in play to cause that...if you're rolling the sidewall over on a turn you are effectively lowering that corner of the chassis, shifting the weight to that point, which could cause a roll...you are also reducing the contact patch of the tire, which would cause it to dig in on a side load but not improve any forward traction.
duuuuuuuude is offline
Old 02-21-2013 | 05:40 AM
  #1209
I'm not sure but i think it has to do with weight transfer. If you ride a 1:1 gocart you are told to lean outward in the turns to get more grip. You put more weight on the outside tires and at the same time create more preasure and grip?
And when your rc car is rolling more it puts more weight on the outside wheels and thereby creating more grip?
daniz is offline
Old 02-21-2013 | 06:25 AM
  #1210
I disagree with your premise. Why do you suggest that reducing roll too much causes traction rolling? The physics should be the same regardless of the surface type. Less roll= less weight transfer= less traction, not less roll to a certain point and then massive traction kicks in.
I think your combining roll center, camber link position, and camber gain, the length of the camber link. However, if we take your example, it sounds like your assuming the camber at corner entry is at 0 and at the apex it reaches a +4. That scenario might work on a very high grip surface where you need to "reduce traction" in the corner to allow the car to rotate or prevent traction rolling. In most off road scenarios, the car is set up with a negative camber, less traction, and as the car transfers weight in the corner the camber gets closer to zero, or the greatest amount of traction.
400units is offline
Old 02-21-2013 | 06:32 AM
  #1211
when you go into and come out of corners you have 2 forces on the tire, lateral and horizontal pressure, body roll applies more downward pressure on the tire, therefore even with a ultra low roll center which causes your instantaneous center (camber gain) to become less neg camber through suspension travel, there is still more down pressure on the tire, weather that will increase rear traction, mybe.... mybe not.
Typically I mover my roll center to get the most even wear on the tire, I will first try moving weight around to induce/reduse roll, then if I cannot get the desired result, I will move my links around!
Sounds like you do not have much weight transfer to the front, many ways to fix this, try lengthening your rear drop by unscrewing the eyelet 2 to 2 turns. I hate drag brake but sometimes its the quickest easiest fix to the problem. I know the last one sounds weird but try adding weight to the back, I found that the more weight that is in the back, the more weight can be transferred off power!
synap2012 is offline
Old 02-21-2013 | 06:38 AM
  #1212
MikeXray's Avatar
The problem is when there is still too much traction even given the less roll, the energy is trying to go somewhere, if the chassis cannot roll to absorb it, it gets transferred to the tires, which dig into the track and the car rolls.
Traction roll is a difficult problem because depending on when it happens in the turn, it could require 2 opposite approaches to fix. (although removing front traction typically always cures it, but at the expense of a push).
MikeXray is offline
Old 02-21-2013 | 06:43 AM
  #1213
Yes raising the front camber link on the tower will allow the front to roll more and give you more traction/steering. If you still need a little more and you want to try another fine tuning adjustment, move your front shocks in one hole at a time on the tower until your desired steering is achieved. You will probably notice some smoother steering too. Post your results.
400units is offline
Old 02-21-2013 | 06:46 AM
  #1214
MikeXray's Avatar
The space we play with on most cars even a high to low roll center change is not a huge variance in camber gain, looking at rccrewcheif they have a model of the Yok Bmax, changing from full short link high roll center to long link, low roll center is only a .44 dg change in gain (for every 3mm of arm movement). I believe if static camber is in the normal 1-2dg range that you are still using most of the center part of the tire.
MikeXray is offline
Old 02-21-2013 | 07:13 AM
  #1215
I have never seen such massive traction that couldn't be compensated for with the right tire selection, spring choice, shorter camber link, and a high roll center. Are we talking about running on carpet? I think we might be talking about a 1% scenario when most of us are going to set up our cars for the other 99% of the off road surface conditions.
400units is offline
