Tune With Camber Links >
Like Tree65Likes
Old 02-21-2013 | 08:01 PM
  #1231
MikeXray's Avatar
Originally Posted by jlfx car audio
Wow at the information overload I asked for . Tks for the views .
Yea I'm just trying to apply the knowledge with this thread to my on road racing as well as of road .
On road we tend to change inner hinge pin location to deal with role center and the camber link is more for camber gain .
Not to mention offroad cars offer way more camber setting changes than on road (wide range )
But anyhoo , with carpet racing traction is super high at times and rolling becomes a issue and stiffening (less role ) setup sometimes makes it worse , so even tho less role scrubs traction it seems to make the rolling issue worse .AAlso with on road we r dealing with flat tires instead of rounded so that's something some of us don't think about when talking about camber setups.
With this said I have a team Durango desc410v2 and it traction roles in the sweeper on our indoor clay track .
It has a short low link in the rear with about 4deg of camber in the rear . But in slower areas it loose . I want to keep it from rolling in the sweeper but don't want to loose and mechanical grip in the rear thru the infield (tight track with a lot of tight turns) next weekend I'm going to try more role in the front and more caber in the rear first (local guys r telling me to go with stiffer front springs but I can't do that correctly without changing the rear for balance .
Am I off in my thoughts on my changes I'm wanting to make?
I agree with the sway bar recommendation, if you don't have one to add, I would try a longer front link or softer front springs.
MikeXray is offline
Old 02-21-2013 | 09:47 PM
  #1232
Originally Posted by tperazzo
In my view weight transfer doesn't depend on roll or springs. Physics say that weight transfer occurs from cornering forces applied at the center of gravity and only track width and ride height affect weight transfer. The springs can't add or remove any forces to the tires since the downforce can't exceed the weight of the car.
Now if you study the roll resistance of the front versus rear that is where you can see how traction moves around. The softer end gets the most traction because more of the weight is distributed to each tire versus the stiff end which may have one wheel off the ground in extreme cases.
This may differ than conventional tuning wisdom, but this is the basics. More complex discussions can involve camber and tire issues, but in my view its important to take a step back and understand the basics. If your car is rolling, lower the ride height, add aero forces, increase track width, reduce traction, or slow down.
"since the downforce can't exceed the weight of the car."
Down force is a force and weight is a mass. Basis physics is F=MA. Trying to imply that a force cannot surpass mass is a flawed starting point. A vehicle can and typically does create more force than it's mass, it is called acceleration. There is so much wrong here, but no time to write a book. It is imperative to understand basic physics/math to apply these concepts to an R/C vehicle, otherwise you will spends years on the wrong road.
Just my $0.02
Turbo
Turbo911 is offline
Old 02-21-2013 | 10:33 PM
  #1233
Just my $0.02
Turbo
Crazy stuff here. My physics class teaches weight as a product of mass x gravity. Mass does not equal weight. Weight is a force. W=mg and is either newtons or lbs. Mass is KG or Slug.
rnpnick is offline
Old 02-21-2013 | 11:00 PM
  #1234
Just my $0.02
Turbo
My quick worded example was based on static cornering loads. Sure, you are right when the car hits a bump loads increase due to dynamic forces. My intention was to describe total lateral weight transfer. Forgive my haste, I don't have time to write a book either.
tperazzo is offline
Old 02-22-2013 | 01:36 AM
  #1235
Originally Posted by bds81175
You need to watch the rate at which the chassis moves back up from a compressed state. Any other movement after the chassis moves back up is pretty much a result of extra inertia from the motor. That's why I prefer the push the chassis down and release it method. Its easier to see the return speed that way. Make sense?
I have done that with three different spring sets and got the same results...that's why im getting confused. Are you looking for it to rise at a certain speed (fast or slow)? P.S. I don't have a high speed camera.
Johnnysplits is offline
Old 02-22-2013 | 03:30 AM
  #1236
Imbalance on a Carisma GT14B 1/16 buggy:
*ww.youtube.com/watch?v=-SQAzbsJyGg
+ YouTube Video
Balance:
*ww.youtube.com/watch?v=Qu9XiLHHVSY
+ YouTube Video
I haven't done enough posts to post links, please replace the * with a w.
Used a slowmo app on my iphone to see it, hard to see on the small scale cars otherwise. It was easier to see with the naked eye on a 1/8 buggy.
daniz is offline
Old 02-22-2013 | 03:57 AM
  #1237
jlfx car audio's Avatar
I'm running a heavy sway bar in front and rear ...
And as l mentioned earlier I will not go stiffer on just one end of the truck that's against this threads rules .
Longer link is a possibility tho
jlfx car audio is offline
Old 02-22-2013 | 04:15 AM
  #1238
wingracer's Avatar
Originally Posted by 400units
I disagree with your premise. Why do you suggest that reducing roll too much causes traction rolling? The physics should be the same regardless of the surface type. Less roll= less weight transfer= less traction, not less roll to a certain point and then massive traction kicks in.
Using high roll centers (geometric anti-roll) can cause a jacking force that in the extreme, can roll the car (traction roll). This is why most independent suspension designs have a roll center well below the cg. This is the main problem with swing axle designs (Corvair, Beetle).
It is possible to have a high roll center with low jacking forces. Most beam axle designs accomplish this.
wingracer is offline
Old 02-22-2013 | 04:40 AM
  #1239
Balance:
Finally a vid on this...Thank You!!
Old 02-22-2013 | 05:13 AM
  #1240
bds81175's Avatar
Moderator
Windows media player allows you to slow down the video to the point of watching it frame by frame if you wish.
bds81175 is offline
Old 02-22-2013 | 06:38 AM
  #1241
Cool thanks!
Old 02-22-2013 | 07:08 AM
  #1242
bds81175's Avatar
Moderator
daniz, nice shaving video....
bds81175 is offline
Old 02-22-2013 | 07:28 AM
  #1243
It's nice to have the ability to shave between heats..
daniz is offline
Old 02-22-2013 | 07:29 AM
  #1244
asc6000's Avatar
the video is cool, I'm so used to doing it by eye the slo-mo took a couple looks.
A reminder, the only rebound you are using for this is the first one. The subsequent oscillation (bouncing) in the rear is simply due to the weight in the back.
Only the first rebound... to judge the spring.
asc6000 is offline
Old 02-22-2013 | 09:22 AM
  #1245
Quite an in depth discourse into the mysteries of RC vehicle dynamics, Good reading! Big thanks to Fred. Many posts back Fred mentioned he did not like to use the term "roll center" as it carries many myths that cause confusion. I found a paper detailing some of those myths, and explains roll center as it applies to full scale vehicles during my research. Might be some help with even more break down of the term:
http://www.neohio-scca.org/comp_clin...namics2007.pdf
He uses another analogy using a broom, sort of makes sense. Remember this analogy next time you sweep the track
NitroLeadFinger is offline
