Tune With Camber Links >
Like Tree65Likes
Old 07-06-2014 | 03:38 PM
  #1786
This guy does a great demonstration
Roll Center Question = Answered
+ YouTube Video
Jason Snyder is offline
Old 07-06-2014 | 05:43 PM
  #1787
Originally Posted by My ST-RR EVO
I'm not sure if raising or lowering roll center would help more or if longer links would help. I'm trying to apply the statement of how a 'low roll center is the most chassis roll (least wheel lift potential)' to my new issue, or if it does. Would more chassis roll make the car more likely to roll over? And also start lifting wheels off the ground since the chassis is rolling over?
See http://www.rccaraction.com/blog/2014...center-tuning/
roundguy is offline
Old 07-06-2014 | 06:32 PM
  #1788
mick33b4's Avatar
Post #89, the bulleted one by Razathorn, in this link is the best roll center tuning description in hundreds of pages of rctech roll center debates.
http://www.rctech.net/forum/electric-off-road/686770-official-camber-link-roll-center-debate-thread-6.html
mick33b4 is offline
Old 07-06-2014 | 07:07 PM
  #1789
R/C Tech Elite Member
I've read this thread from start to finish over a six week period but I'm still not clear on the correct definition of pack.
Some people seem to be describing pack as the point where a shock effectively reaches a hydraulically locked state.
Others seem to describe pack as a gain in dampening rate as piston velocity through the oil increases, which may or may not ever reach a hydro lock state.
I think the latter is the more correct description but I'm just not sure from what I've read. Am I close or am I still off on my understanding?
I believe I understand now how to adjust the amount of pack I get but I'm trying to visualize what happens when I land a jump with more or less pack in my shocks. I'm not completely sure if it's a sudden stop of suspension travel at a certain point or not. I think the answer is that it can be a sudden stop but that's probably not what you want to tune for.
Anywhere close? Am I even making sense?
iScream is offline
Old 07-06-2014 | 08:14 PM
  #1790
The RC Car Action link corroborates the video and quote 1 and 3 below... "Using a higher roll center prevents the car from leaning as much, which is helpful on high-bite tracks to minimize traction rolling and will also give the car a snappier feel—good for smooth, high-bite tracks."
1)
Originally Posted by K_King
Higher roll center to keep the car flatter. Lower on the inside/higher on the outside.
2)
Originally Posted by ufoDziner
According to RC Crew Chief lowering the RC is what you get by lowering the inside, but it will keep the car flatter.
There is confussion, but lower on the tower = higher roll center and vice versa.
3)
Originally Posted by fq06
Yeah, I've seen discrepancies in tuning guides but my experience is lower inside link keeps it flatter and higher promotes more roll. How that affects your traction is another thing. Sometimes less roll is more traction or more roll is more traction. All depends on the track surface and what your trying to accomplish.
4)
http://www.rctech.net/forum/electric...-thread-6.html
Great info!
I have a feeling there is a LOT more to this than just raise or lower the link as quote 3 warns. I swear I had a lower front roll center (higher on tower) that was dealing with the traction rolling better than when I went to a higher front roll center (lower on the tower). Steering became more immediate with the higher front roll center and my car traction rolled more immediately. I will do more testing with this specific info in mind. Thanks for the great info everyone.
My ST-RR EVO is offline
Old 07-06-2014 | 08:25 PM
  #1791
+ YouTube Video
That was a great video. I have no idea how to put a Youtube video on here, but his part 2 "Roll center demo 2" makes it even more clear.
Old 07-06-2014 | 09:45 PM
  #1792
2) There is confussion, but lower on the tower = higher roll center and vice versa.
Doh! I was zoomed in on the wrong link (lower inner pin height can be changed on my car).
ufoDziner is offline
Old 07-07-2014 | 04:52 AM
  #1793
If you want to see what is happening to your roll centre plot it on some paper. One advantage is that you are using a 1/10 scale car, so you could hold the front and rear of the car up against some paper and mark off all the pivot points, move the suspension in increments and mark it again. Do this for all your normal link positions and you will get a plot of what is happening to the roll centre.
Someone at the weekend said you have lowered your roll centre because I had gone to a shorter link on the front, but I could have lowered the outer link height and raised the inner link height and had the same roll centre as the longer link at the same ride height. I would have had a roll centre that would have moved more due to changes in ride height and one that changed camber on the wheel more through the suspension movement.
The weight will transfer to the front through the roll pitch which is the difference in heights of the front and rear roll centres, so normally most rwd weight rearward cars have the front roll centre lower at the front than the rear to transfer the weight forward.
Also the higher the centre of mass the more weight transfer to the front and rear and side to side. If your rollcentre is higher than the centre of mass you get negative transfer of weight about the roll centre as you corner ie the part of the weight transfer equation that is weight transferred due to the roll centres reduces load on the outside wheel. At this point there is still an increase in weight on the wheel due to weight being transferred globally from its central roll centre (where the centre of mass hits the pitch angle between the front and rear roll centres).
Its all a bit of a fluid system so realistically you are back to just trying things out. The only way you could make sense of it would be to work out the G pulled by the model in a corner and record loads of setup data and calculate the load transferred in a corner. Then at some point you might have enough data to find some magic numbers that work on different track surfaces that require different tyre slip angles (that's also a big bit of data missing in the RC world compared to fullsize).
Also you wont find too many fullsize race cars with 50/50 weight distribution as that tended to give inconsistent handling, most seem to have going up towards 60pc weight at the driven end.
Rsimps is offline
Old 07-07-2014 | 05:06 AM
  #1794
Also a lower roll centre has the potential to create more vertical downward grip on the tyre during cornering if the correct springs are used. If you use the same springs and you lower the roll centre the body will roll more as more load is being pressed on the springs of the same poundage. In the full size world you would go up to stiffer springs to control the chassis and tyre angles. The stiffer the spring the more load the wheel is seeing. If the tyre can handle that load you will gain grip, if you overload the tyre you will strub the tyre and the tyre will slide.
What you are dealing with in RC sometimes is grip roll on high grip tracks, therefore you probably have tyres that can grip far more that in the fullsize world and therefore you are tuning outside of the parameters of most fullsize competitive vehicles.
Rsimps is offline
Old 07-07-2014 | 07:10 PM
  #1795
W.E.D.Jim's Avatar
Separate issue now. Our track being run dry and blue grooved. My car is traction rolling everywhere. I can't push it at all... unless it's going straight.
I stiffened the shock oil incrementally up to the thickest oil the hobby shop had, 60wt Losi. ...and the smallest hole pistons I had (1.3x8 down to 1.2x8), cut some droop, lowered the car and went to a stiffer front sway bar (2.3mm to 2.5mm) and heavier springs. With these changes the car was massively better, but it's still not enough.
Think of chassis roll they way we use anti-squat.
Basically, the rolling motion, side to side, or front to back, is energy being absorbed, rather then sending it to the tires.
More anti-squat uses the chassis energy to push on the tires, rather then squatting.
More chassis roll, absorbs the energy the tires would see as chassis roll instead.
Keep in mind though that sometimes traction rolling can't be tuned out. So if tuning to the max doesn't help, you may need to attack the track differently, try different compounds, sauce, etc. to reduce or eliminate the issue.
Hope this helps.
W.E.D.Jim is offline
Old 07-07-2014 | 07:16 PM
  #1796
W.E.D.Jim's Avatar
If anyone doubts the roll center tuning discussion as it looks, think about old versus newer cars.
Older cars were raced on bumpier, lower traction, even sandy tracks. Pin spike tires, etc.
They came with short arms, short camber links and had high roll centers. Lots of camber change to produce traction and aid in bump handling.
New cars...longer arms, longer links that are also flatter. They are trying to take camber gain away and lower the roll centers as much as possible to reduce traction on high bite, smoother tracks. Making modern cars easier to drive fast on today's tracks.
I'm not looking to argue the point, but it's seems black and white to me. Even at the highest roll centers our new cars probably can't get to where an RC10 was as far as HRC.
Old 07-07-2014 | 08:23 PM
  #1797
I think you have high and low roll centers backwards there. I believe the older cars had lower roll centers, resulting in more roll and higher traction on old bumpy tracks.
iScream is offline
Old 07-07-2014 | 09:03 PM
  #1798
This is completely backwards.
fredswain is offline
Old 07-07-2014 | 09:04 PM
  #1799
Nope. He's right.
Old 07-07-2014 | 09:15 PM
  #1800
Originally Posted by fredswain
Nope. He's right.
What am I missing? A lower roll center results in more chassis roll during cornering, right? Are you saying the video posted on this page is wrong?
Did I at least get close with my description of pack toward the top of the page?
iScream is offline
