Serpent 811E Buggy Thread >
Like Tree5Likes
Old 12-04-2011 | 10:38 AM
  #901
porkchop - did you talk with billy yet ?
taztal3 is offline
Old 12-04-2011 | 10:44 AM
  #902
porkchop's Avatar
one project at a time is what i been told
porkchop is offline
Old 12-04-2011 | 11:18 AM
  #903
okay sure
taztal3 is offline
Old 12-04-2011 | 02:09 PM
  #904
spunkysandoval's Avatar
Just have to wire the motor up but I didn't have any 4mm bullet connectors to finish the job. This Q-base esc from HPI uses 4mm bullet connectors on the esc for the motor and solder posts for the power wires. I routed the sensor cable under the radio tray and it seems to work well.
I am less than impressed with the quality of the hardware this kit uses. I replaced most of the included hardware with my own stuff. I'm using the stock bladders for now with foam compensators that I made. The stock bladders are useless without them. Also, I was kind of let down when I found that there was a few philips screws included instead of hex hardware for the bearing retaining screws that go into the diff (see pic below)
Philips screw? Really?
spunkysandoval is offline
Old 12-04-2011 | 02:16 PM
  #905
teeforb's Avatar
Originally Posted by Captainlip
are you sure one of the screws holding the mid driveshafts in isnt rubbing the diff gear?
Mine did so I just put two in each diff.
I don't think so. The sounds coming by center pinion/spur. Like I mentioned, sounds like the rec box is amplifying the noise. Maybe things just needs to settle.
teeforb is offline
Old 12-04-2011 | 02:56 PM
  #906
Jpm1's Avatar
So that's a NO on the e-truggy I take it?
Bugger!!!
Jpm1 is offline
Old 12-04-2011 | 03:33 PM
  #907
porkchop's Avatar
thats not a no on the etruggy that are gas buggy need updated.
as for the screws in the gear box you can replace them but we been thought 4 differnt screw to find one that holds up
take it all back apart drill the hole smaller then 3mm and use a 3x5mm button head screw then look where the bearing ride clean up the mushroom plastic form adding a bigger screw
porkchop is offline
Old 12-04-2011 | 05:56 PM
  #908
Has anyone done a velcro strap on the batteries yet?
Old 12-04-2011 | 06:27 PM
  #909
teeforb's Avatar
The body does a great job covering the body. Does the motor/Esc stay cool?
teeforb is offline
Old 12-04-2011 | 06:47 PM
  #910
porkchop's Avatar
my car had motor for days and noting got over 120 degs motor side and speedo past 95
porkchop is offline
Old 12-04-2011 | 06:57 PM
  #911
bigjayjay1's Avatar
Guys I'm struggling with the ebuggy the rear isn't as planted its not taking to the track very well.
553 diff
30wt blue front 35 purple rear 8 hole tampered 1.3
27 front 28 rear height
Droop 99 front 116 rear
Sway front 2.3 rear 2.5
Shock front third hole down tower -a arm inside, rear third hole down -outside a arm
Camber rear tower inside down hub closes hole near tire, front tower upper hole and hole closes tire
1.5 toe right left =3 degrees
I've made a lot of adjustments this is the best so far but I'm not happy with its performace. Also it has a slight push but the rear is fish tailing I've tried every tire trust me I have many types settled on ibeam soft.
Track is technical light dust size small. I'm not able to keep up cause I'm worries about the rear and I'm baby it and losing track time. Thinking about dumping and going Los I tekno.
bigjayjay1 is offline
Old 12-04-2011 | 07:02 PM
  #912
porkchop's Avatar
553 diff
Sway front 1.3 rear 1.3
i droped you a pm with my number call me and i get you fixed up or try and help
dont dumb it jay i got some stuff that help you
porkchop is offline
Old 12-04-2011 | 07:06 PM
  #913
bigjayjay1's Avatar
Thanks pork will give you a call heading out for a family Sunday dinner. Today's race was the best so far placed fourth a main but my times are off.
Old 12-04-2011 | 07:11 PM
  #914
netmaster's Avatar
FYI about the transponder mounting.
During testing Billy was having problems with the transponder counting when the transponder was mounted under the ESC, hence the reason it has a different mounting location shown in the instructions.
netmaster is offline
Old 12-04-2011 | 07:13 PM
  #915
porkchop's Avatar
i have my transponder right on top of the servo it raise the body a mm but i was in hurry
porkchop is offline
