Serpent 811E Buggy Thread
#736
Working on putting my Serpent together. I was wondering how tight the diff is on your guys cars. I know the manual says it takes a hour to break the diff in. I out my rear diff together the way the manual says and it is a little hard to turn by turning the drive shaft with your fingers, just wondering if this will free up.
#738
Thanks guys! If any of you got more race stories with this snake I'd love to read about them (or vids, I know Frank has one out). Heck I might as well get some satisfaction threw others if I can't get it myself, wait that doesn't sound right? Looks like it's maiden voyage will be next wk the 3rd. We're having a big race called the Winter Blitz. What a way to get a first run in with a new rig,
#739
teeforb This would look really good with the 811BE
http://www.rctech.net/forum/electric...-must-see.html
No videos, but this past Sunday racing at ARCs, my 811BE ran the first ever 18 lap run on this layout, and cranked out a 17:07 sec. lap. Helped that the traction was really good. Also, in the main, every lap was in the 17s, and my consistency was 0.20. Went to practice Tuesday and made a few more changes that felt better.
#740
Revolectrix are ones of the best chargers now produced. I am already using CellPro 10S for charging my 1/8 e-buggy 2x2S LiPo batteries and it works exceptionally accurate and quick. It is very simple and very smart charger. If someone is looking for simple good charger to charge 2x2S LiPo batteries - go for it!
And PL6 and PL8 have nice feature for dual (or multi) channel operation - Expansion Channel Mode. Every unit is already set up as a Primary. Each additional unit can easily be programmed as an Expansion Channel. The Primary sends the currently selected preset out to each Expansion Channel. The only buttons you press after that are the Primary's. Start any operation and each unit begins to charge, discharge, cycle, or monitor the packs connected!
#741
maxxing will get you set up next firday
start with the base set up eric posted a few pages back and then i help you tune to you.
#742
NOTICE: to those building their 811e and those that have it built. The metal upper arm links that connect the upper arm links to the shock towers need special attention. I have had 2 of them come undone even with blue threadlock. That metal seems to have a thin layer of oil in the threads that effect the blue threadlock. Be sure to clean out the oil with something or use longer screws with more threadlock.
#743
All the screws in the kit seem to have oil on them. I hit them with motor cleaner before installing them and that seemed to help. I also cleaned any alum parts that screws went into with motor cleaner and so far there hasnt been any issues. I had the same issues when I built the truggy, I had many loose screws no matter how much loctite I used.
#744
yes all serpent screws have oil on them i ask why 1000 time no answer so spray them with motor spray makes life easer
#745
well i didn't notice the screws having oil on them, only the metal parts they went into.
#746
#748
As for using any threadlock you should clean both threads with something like brake cleaner before assembly.
#749
Missing part help
Hi Everyone,
Just got my Serpent and I'm trying to put it together. I'm on page 7 steps A 10 - A 110
The little washer that the M3x18 screws into while connecting the rear diff to the shock tower - is that washer this: http://www.amainhobbies.com/product_...-Washer-Set-12
I seme to not have those in my kit.
Thanks.
Thanks.
#750
Hi Everyone,
Thanks.
Thanks.
