Like Tree5Likes
SC10 4x4 Thread
Old 11-12-2011 | 05:46 AM
  #10726
Awesome thanks marcus, yes let us know how it goes, btw hows ackerman bar testing going, u seeing any improvements???
rickybobbyxxx is offline
Old 11-12-2011 | 05:52 AM
  #10727
Chad Smith's Avatar
Originally Posted by symmetricon
+1 worst case senario, it would weight in like a losi.
I thought the same thing then we would be in the same boat trying to lighten the truck
Chad Smith is offline
Old 11-12-2011 | 06:48 AM
  #10728
I dont know if u guys have noticed, but the whole weight thing seems to be working tor the losi
Old 11-12-2011 | 06:54 AM
  #10729
Evil Genius jr.'s Avatar
Whats the best way to put o a pinion that wont fit through the mount hole?
Thanks!
Evil Genius jr. is offline
Old 11-12-2011 | 07:22 AM
  #10730
BlueGlowBoy's Avatar
Thanks!
I've seen people drill a small hole in the inner gear cover, either from the top front (around the 2 o'clock position) or directly from the bottom (6 o'clock) and then covering the hole from the inside with some tape or something.
Personally, I've taken an allen key and cut it down so that it will reach just long enough to tighten my 17t 32p pinion right down. it's a little awkward the first few times, but imho, unless you run on different tracks that require different gearing, you won't change pinions often, and I didn't want to drill a hole in my gear covers...
BlueGlowBoy is offline
Old 11-12-2011 | 07:43 AM
  #10731
Thanks!
Old 11-12-2011 | 08:05 AM
  #10732
Slotmachine's Avatar
Originally Posted by We already have the lightest truck on the market. You could literally duct tape Fishing Lead to the chassis pan and achieve the 2mm lower LCG. I won't deny the trucks look gorgeous with the three things i'm attacking. But don't staple Performance when [U
you bundle the three together[/U]. (emphasis on bundled)
Durango is the lightest truck on the market...............
Slotmachine is offline
Old 11-12-2011 | 10:03 AM
  #10733
Thanks!
You can also cut a small notch in the center divider in the belt cover.
Sofa King is offline
Old 11-12-2011 | 02:15 PM
  #10734
MantisWorx's Avatar
so far so good on the testing , been at the track all day today. it works very well. kinda hard to explain it, you dont lose steering(turning radius) but its not edgy it seems more consistent in that how ever you have it set it stays the same throughout the turn. this morning the track was loose so i put the links forward and got more bite, as the day went on and the track got looser i moved to the center and steering felt close to the same. i didnt clearance enough of the arms to go to the last hole which i think would have been even better!
i did mange to beat my best time with a 23.7 but that is not entirely due to the ACKbar, i have some other things in the works too!!
MantisWorx is offline
Old 11-12-2011 | 02:20 PM
  #10735
Potoczak's Avatar
Hey guys can someone post a link for the correct traxxas hexes the some guys are using to make the truck wider. thanks
Potoczak is offline
Old 11-12-2011 | 03:56 PM
  #10736
Default shocks
I read on someones post they changed shocks.What make of shock and where can I get them? of my shocks leak and I can't stop them.,would love to replace them but with what?
Thanks in advance,Butch
butchman is offline
Old 11-12-2011 | 03:58 PM
  #10737
JEFFs SC10's Avatar
Has anyone had problems with their rear differential makng a crunching noise?
JEFFs SC10 is offline
Old 11-12-2011 | 04:36 PM
  #10738
old&slow's Avatar
Default traxxas hex
the wider hex are part # 3654 , and you will need to drill them out to 6mm to fit the axle
old&slow is offline
Old 11-12-2011 | 04:42 PM
  #10739
Basher only
bohdi is offline
Old 11-12-2011 | 04:53 PM
  #10740
CoyoteSlash's Avatar
Originally Posted by bohdi
While you all sit there and make mods, play with set-up, yadda, yadda, yadda, none of you have come to grips that the car is a basher only. I am an AE fanboy and know it is a POS when it comes to racing
I will not sell it as my 8yo loves it for playing in the yard but YOU will not be able to truly compete on a track with any mods. We are not the Ryan's and never will be. The Losi sucks too as you have to spend more money to upgrade the soft metal but it is so heavy and planted, we cannot compete unless you have a long main where you know the batts will dump on th Losi.
I suspect AE knows this as well. I am sure I will get flamed but it is the truth.
BTW, I post this knowing I have not had one issue that everyone else has had either. No slipping belt, no bent cvds, no warped a-arms. I do have the clutch basket though.
I will not buy a Losi though and would rather dump the class but will probably build an sc10 out of excess rc8 parts.
Truly. And I mean this... I have never read more Invalid opinion in my life. Congratulations.
CoyoteSlash is offline
