Like Tree5Likes
SC10 4x4 Thread
Old 12-09-2012 | 11:38 PM
  #31591
heavyjeffd's Avatar
Originally Posted by Wild Cherry
tighten slipper
1/4 turn at a time
do not lock it up
replace slipper lock nut for new one cus it may be the real issue
I personally can run with out the spur gear cover on .
Helps the slipper & motor run a lot cooler ...
cooler motor & slipper improves performance
You converted your sc104x4 to a touring car?
Just kidding.
heavyjeffd is offline
Old 12-10-2012 | 01:59 AM
  #31592
Originally Posted by t0p_sh0tta
The springs, and a ride height adjustment.
Originally Posted by Cain
Those little c clip looking things that clip onto the shock shafts. You will want to use those before putting on the lower cup. So, it would be:
- C clips
- Lower cup on top of these
- any C clips used for limiting travel
These clips will raise up your lower cup to take up the space so you don't need to have some much preload on the spring for ride height.
The spring cup slides over the c-clips. This raises the cup upwards. So starting from the bottom of the whole shock assembly it goes like this:
- Shock Spring put on first
- then C clips on top of the eyelet
- Then bottom shock cup OVER the c clips
- Then any C clips (you may put these on with the other c clips, just make sure they are separate) that you are using to limit up travel.
Thanks for the help guys and thanks Cain for trying twice to get me set straight.
Heres the end result.
Not sure if I did this right?
If I did do this correctly all I have to do now is set the ride height?
24mm?
So this is how my rear shock looked with a rear spring and set for 24mm ride height
This is how it looks with the Front blue spring on the rear shock.
I have the ring that adjust ride height spun all the way up so theres no compression on the spring.
With 2 of the C Clips that have the #2 on them under the lower cup everything sits flush with no compression.
My question now is do the C Clips sit outide the lower cup like this?
or do my C Clips sit inside the lower cup like this? If so, how many more c clips are needed to rise lower cup up? Is there any tricks to getting the rideheight set with front springs on rear? Or is it still spin the plastic wheel on shocks as needed and just measure from the center of the chassis or some people do the crack where the rear and front chassis meet with the center? Sorry I really couldn't find a pic of the finished result as template, epic fail on me. I even used search
AE SC10 4X4 is offline
Old 12-10-2012 | 02:17 AM
  #31593
murky123's Avatar
front springs are for the front
rear springs are for the rear
If you wish to use the front or rear springs otherwise, your bound to come across with some other issues like ridehight adjustments
murky123 is offline
Old 12-10-2012 | 03:18 AM
  #31594
Newdieselguy's Avatar
What kind of parts are you guys breaking while racing?
Or what spare parts do you guys recommend I have on hand?
Newdieselguy is offline
Old 12-10-2012 | 06:14 AM
  #31595
t0p_sh0tta's Avatar
Nothing yet. I keep a set of front arms, and a spare diff. I've read on here that a few have broken the steering assemble, but I've never seen an issue in perosn.
t0p_sh0tta is offline
Old 12-10-2012 | 07:11 AM
  #31596
PastaBoyNY's Avatar
Front arms for warping and tensioner pulley bearings.
PastaBoyNY is offline
Old 12-10-2012 | 08:56 AM
  #31597
Front arm is warped, broke front skid plate, rear shock tower (got dropped by a marshal right infront of another car at full speed), diffs (get the shims correct), bent dog bones in rear, also, all four of the bearings in my stearing will hardly turn. Other than the shock tower everything else is normal wear. I just tore the whole thing apart after Saturday's race how I found the front arm is messed up. Got all parts ordered will actually do Max Flurer's setup from 2012 Psyhco Nitro Blast on it.
MunchMunch is offline
Old 12-10-2012 | 09:02 AM
  #31598
BorackBasher's Avatar
Does anyone make an aluminum steering rack for this truck? I keep on snapping the servo saver. So annoying.
BorackBasher is offline
Old 12-10-2012 | 09:30 AM
  #31599
heavyjeffd's Avatar
Only thing I ever replaced on mind were idler gears, diff gears (after many many races) and body posts. Very durable car.
Old 12-10-2012 | 09:44 AM
  #31600
BentKa's Avatar
STRC makes one: http://www.teamstrc.com/index.php?ro...tegory&path=66
Just make sure you have a servo that's up to the task as this wont break if you take a hard hit
Bent
BentKa is offline
Old 12-10-2012 | 09:53 AM
  #31601
Does any one have some good info for us newbs. Im looking for something PDF, Book, website, that would have info on what changes made to 2wd and 4wd does, example camber height, length angle, sway bars, shocks adjustments, etc.... Like a RC bible?
blusporttrac is offline
Old 12-10-2012 | 09:55 AM
  #31602
Wild Cherry's Avatar
Tech Legend
Just kidding.
Indoor clay , it gets her done ....
The 16mm shock project is going great ....
blusport
This thread is the best place for help & use www.rc10.com for set-ups
Wild Cherry is offline
Old 12-10-2012 | 10:01 AM
  #31603
Cain's Avatar
Tech Legend
I use the hudy offroad setup guide that is available for free.
http://www.teamxray.com/teamxray/sho...p?file_id=4461
Cain is offline
Old 12-10-2012 | 10:03 AM
  #31604
Tech Legend
Originally Posted by RavensNightFury
ask again
No real need for the steel , just add ballast as the Ae team set-ups suggest using .
Old 12-10-2012 | 10:10 AM
  #31605
Cain's Avatar
Tech Legend
hey guys i wanna get back in to sct 4x4 next year and i wanted to know if i put a steel middle bit in the sc10 4x4 would it make it handle better planet on the ground or should i go somethink like the tekno sct but i really like sc10 4x4
RavensNightFury : If by steel middle bit you mean the exotek chassis, I would say if the track you plan to race on would have the vehicle benefit from more weight, you cannot beat the location of where the exotek chassis is located as with the stock chassis, you are not going to be able to add weight as down low as the exotek chassis adds it.
I am seeing benefits to the chassis on tracks that are loose. An overall benefit in that you don't get pushed around by the losi's as easily either.
Cain is offline
