Like Tree5Likes
SC10 4x4 Thread
Old 03-16-2012 | 07:06 PM
  #19366
Oasis's Avatar
Originally Posted by JEFFs SC10
Ok roll call, who's gonna run their truck tomorrow?
It's suppose to rain tomorrow..
Oasis is offline
Old 03-16-2012 | 07:21 PM
  #19367
BlueGlowBoy's Avatar
not me! LOL
Manitoba Robot Games tomorrow. In Tethered Mini Sumo my kid got 4th 2 years ago, 3rd last year, and this year, the 2 kids that beat him last year are in the next age catagory!
BlueGlowBoy is offline
Old 03-16-2012 | 07:50 PM
  #19368
Cameron Kellogg's Avatar
ME! Some more center diff and weight placement idea's to test.
Cameron Kellogg is offline
Old 03-16-2012 | 08:29 PM
  #19369
Questions?? Front shocks in the rear
I was just wondering if anyone has tried using complete front shocks in the rear instead of the limiters under the spring cups. I have tried the limiters but was thinking this might work better. When I tried the front springs I used the 2 mm spacer along with the rubber spacer which I think was also about 2mm.
Since front bodies are 26mm and rears are 30 mm, thought it might be worth a try.
JimH2k2 is offline
Old 03-16-2012 | 08:31 PM
  #19370
MantisWorx's Avatar
spurs came in today!
MantisWorx is offline
Old 03-16-2012 | 08:32 PM
  #19371
ABN Hoosier's Avatar
can someone link me to the pics of the "Center diff" I keep reading. Cant seem to find them...
ABN Hoosier is offline
Old 03-16-2012 | 08:34 PM
  #19372
MantisWorx's Avatar
http://www.rctech.net/forum/electric...-services.html
Scroll down
Old 03-16-2012 | 08:40 PM
  #19373
ilanstylz's Avatar
Here is a pic of Mantis center diff mod on my sc10 on the inside are the washers and diff balls.........
ilanstylz is offline
Old 03-16-2012 | 08:43 PM
  #19374
JEFFs SC10's Avatar
I'll be running practice laps with mine. Wish I had more packs. Just gonna drive it not really work on changes.
JEFFs SC10 is offline
Old 03-16-2012 | 08:51 PM
  #19375
PastaBoyNY's Avatar
Default Not sure...
Jim, you may not get enough droop with the shorter shocks. Just my two cents. If you do try it, let us know how it works out! I just think that you may have to lower the top mount a bit to still have enough downtravel.
Sal
PastaBoyNY is offline
Old 03-16-2012 | 08:55 PM
  #19376
Great!
I have a couple of things I came up with I will share with you if it makes it through a day at the track.
Old 03-16-2012 | 09:10 PM
  #19377
vito's Avatar
what do i look for in frist run and look over for.
vito is offline
Old 03-16-2012 | 09:11 PM
  #19378
PastaBoyNY's Avatar
Thumbs up CF Risers mounted....Weds for testing
I just mounted the CF risers on for the rear camber link. Also added about 5mm of ballstud washers on the inner mount. Should kill some of that LEANING feeling....lol. Working/thinking of some more "out back" driveline ideas. Thank god for people here that you can bounce ideas off of! Its amazing that when you think of something and then think "nah, thats just too crazy" then you bounce it off of someone with more tech knowledge it suddenly doesnt seem too far fetched....lol.
Marcus, keep up the good work!
Cameron...keep up the good work!
Craig, thanks for the ideas!
Coyote....Braces are doing GREAT, cant wait for the diffs!
Everyone else that I KNOW im forgetting....keep the ideas flowing....and thanks to you too!
Sal
Old 03-16-2012 | 09:36 PM
  #19379
CraigMBA's Avatar
The shock length is correct, the (unloaded) height of the spring is too short and will fall out of the bucket at full droop. There is nothing wrong with the spring, it really wasn't designed to be on a shock as long as we are using it.
What would fix it is an eyelet with an extra 2mm of plastic on the shock shaft side. Or you can just clip on a 2mm travel limiter, placed between the eyelet and the spring bucket.
CraigMBA is offline
Old 03-16-2012 | 10:57 PM
  #19380
heavyjeffd's Avatar
Anyone have problems with the belt tunnel bending? Seems like mine is bowing out to the right (over the battery). I have a completely new assembly but I'm not sure why it's bowing out like that. What would cause it?
heavyjeffd is offline
