Cleaning agents
#17
Suspended
For the air compressor I just went to harbor freight and picked up a 1 gallon pancake compressor. I think it was even on sale for $45? I figure even if this thing blows up a year down the line I wouldn't be out too much money. It does 125 psi and has worked flawlessly for what I need it to do.
I also picked up some simple green .
I haven't used it yet. I need to clean up my buddy from a rough weekend at the bashing grounds. I really abused it learning the track and how to drive
#18
i use the air compresser to get most of everything off the truck first then i use this stuff called inox. its a food grade silcone spray that keeps the plastic parts from drying out from the clay and it also helps with the joints and hinge pins. i usually spray it on. let it is for a while and then blow it off again with the air hose. makes it new looking and shiny
#19
And I thought a guy at my local track was kidding when he said he does that. Now I have to try that
#20
What do you guys and gals use to clean out gear differentials where there is plastic and metal? What about shocks when going from one wt to another wt?
