MAMBA MAX PRO COGGING "E_REVO"
Hi i have e-revo with a mamba max pro esc , neu-castle 1800kv motor and 6s lipos. Today it started cogging/glitching when i apply the throttle. It wont go forward until i give it a little tap and the motors turns over and works. But when i stop i have to give it another tap to go. Let me know if there is anything i can do to fix this. thanks.
You probably overheated it. So, Something on the board blew. Just send it in to Castle, they will get it fixed for you.
Also, does the esc smell like an ash tray? If so, you are 100% it has been overheated or it fried.
Like stated above, you need the right esc for a monster truck. Get a Mamba Monster Max instead.
I dont now what you guys are talking about it my esc never gets hot on me at all trust me i checked plenty of times and it does not smell. I just went to drive it and this was happening.
No reason to waiste time to make a MMP work well in a moster truck, I would get a Xerun (cheap, sensored, reliable).
For a cheap fix now try one of these
http://www.amainhobbies.com/product_...tage-Protector
I've had to get one for each of my mmp's. I've ran my MMP in my 8th scale buggy with no issues. I dont see why it wouldn't work in a erevo. If it doesn't help then pick up a mmm.
Get an MMM or an RX8 for MT's period.
i have a emaxx with mmp it runs fine on 4s and 5s but on 6s it does the same thing thats happening to you i would get a mmm for 6s but im ok my 2150kv tacon motor is fast enough on 4s
I dont see how that voltage protector would fix it that is just to get it more power for the servos.
A BEC that castle makes dose the same thing powers the rx directly off the battery and then inturn dose give a servo more power.
but you have to cut the red wire to run on from your esc witch eleminates the bec from the esc (HUGE problem on the MMP is the WEAK bec witch inturn causes a Glitching like problem)
What causes this crap? I can deal with it being not quite as smooth or as fast as the kinetic but that "Cogging" basically ruins a race.
Oh and I run the extra voltage protector/capacitor thing.
