SLASH Suspension Issues >
Old 03-30-2011, 11:15 AM
sc10pc's Avatar
Default SLASH Suspension Issues
hey guys ive owned the slash for a little over a month now and really like the truck. the problem that im having is the shocks are just way to soft. most of the issues i believe to have to do wit the battery. im running a duratrax 5000 MAH 7-cell pack and the thing weighs like 2 pounds. i tryed changing the shock oil from 25 wt. to 40 wt. and that didnt seem to do a thing. what should i do
sc10pc is offline
Old 03-30-2011, 11:21 AM
racer53's Avatar
One word...Lipo
racer53 is offline
Old 03-30-2011, 11:25 AM
sc10pc's Avatar
dude i dont feel like droppin 300 bucks on a couple of lipo's and the charger do you have any other solutions like maybe 1/8 scale shocks
sc10pc is offline
Old 03-30-2011, 11:30 AM
racer53's Avatar
Thunder Ac6 charger from hobbypartz.com $55
2 Turnigy's Lipo's from hobbyking.com ~$65-70
Deans conectors $8
Correct me if i'm wrong but that is probably going to be the cheapest route.
racer53 is offline
Zako51's Avatar
Trader Rating: 20 (100%+)
Do you have those shock spacers that came with your truck. They look like black rings. They come on a plastic "tree". Put a couple of those on the upper part of each shock. They will stiffen the springs and strengthen the rear end.
Let us know!
Zako51 is offline
Old 03-30-2011, 01:00 PM
R/C Tech Elite Member
blade329's Avatar
Trader Rating: 114 (100%+)
25wt??? That is way too soft for a Slash. You want to go 50wt in rear and 45wt in front. There are also spring kits you can get or you can go with the Pro-Line Powerstroke shocks. Very good shocks.
You really should go lipo. They really have come down in price as have the chargers.
blade329 is offline
Old 03-30-2011, 01:23 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
You will need to increase shock weight oil to get the proper dampening in the shocks. You might also want to play around with spring rates too.
BuggyKing is offline
Old 03-30-2011, 02:55 PM
sc10pc's Avatar
thanks for the comments guys. curently i have one huge spring clip in the fronts and 1 huge 1 medium and 1 small clip in the rear. i mean how much more pressure can i put on those shocks ive been looking around on the internet for 1/8 scale shocks that would fit on the slash but cant seem to find any. also lipo has come down in price but i dont have any clue about lipo's and how reliable or anything about them? the front shocks are fine but the reare sag like an inch off the ground its either "lipo" or "bigger better shocks" which one
sc10pc is offline
Old 03-30-2011, 03:00 PM
Neu_Racer's Avatar
Trader Rating: 211 (100%+)
Absolutely Lipo!!!
Someone has a great sig on this forum but can't remember who. Says "guns and lipos are only dangerous in the hands of stupid people!" and it's very true.
If treated even somewhat properly, lipos are just as safe as Nimh or anything else. Even more so kind of. I've had 2 packs in my life blow. 1 Nimh and 1 lipo. The lipo caught on fire and destroyed a 1/8 buggy costing me $500 give or take. Flames were put out and only thing injured was my hobby fund.
The nimh while charging exploded like a friggin pipe bomb and sent shards of crap into my drywall 10 feet away.
Even 40wt oil is too light. Get a cheap lipo and charger and save up for some Losi 8ight shocks or Proline powerstroke. If using 8ight get fronts only for all around.
Neu_Racer is offline
Old 03-30-2011, 03:36 PM
Planespotter's Avatar
I couldn't agree more with the lipo. I was resistant to trying lipo for a lot of the same reasons, but now that I have some I am kicking myself for not getting them sooner. The performance advantage is pretty big, and if you handle them with a minimum of common sense you will be just fine. Put it this way, you probably already have stuff sitting in your garage that is far more volatile than a lipo battery pack.
Planespotter is offline
Old 03-30-2011, 06:36 PM
sc10pc's Avatar
ok so lipo is probably the way to go then! does anyone have any links to some cheap lipo's and the charger
sc10pc is offline
Old 03-30-2011, 06:41 PM
stock springs are soft as it is. order stiffer ones at the same time.
and still get the lipos. the performance gain is well worth it.
hammer down is offline
Old 03-30-2011, 06:42 PM
koopesv's Avatar
Trader Rating: 18 (95%+)
Get yourself some of these, I run them and they are good not the greatest ones I've ever had but Im keeping up just fine at the track.
http://www.hobbypartz.com/gens.html
And you want to run 60wt in the front and 50wt in the rear or 50/50 thats a good starting point.
You can also use the Traxxas red springs in the rear and the black up front.
koopesv is offline
Old 03-30-2011, 08:03 PM
sc10pc's Avatar
ok ill start off with lipo's but i still want some upgraded shocks because face it the stock shocks suck after researching what "Neu_Racer" said about the losi eight shocks i wanna get the front shocks off the eight for all round on my slash but cant find were to get em
sc10pc is offline
Old 03-30-2011, 08:34 PM
nitrofreek77's Avatar
x2, I run zippys tho.
Deans conectors $8
nitrofreek77 is offline
