OFNA Nexx 10sc Thread
#496
I would.go back to the white shocks play with preload on shocks. That is were i would start sounds crazy but trust me ,Me amd another guy are running the Nexx and we both feel the shock seem soft.
Also the goose bumps do not have alot of side biteif the track is real loamy i would go with am3 bowfighter on this truck.
#497
#498
No traction rolling, just bad bound. I even tried 50wt oil and it just didnt work out.
Honestly, the stock nexx shocks are smaller than the other 2 ofna trucks out there. Wonder why Ofna decided to go with a smaller shock.
#499
I ordered some D8 Big bore shocks, and a Jammin Product Front shock tower. They should be here soon. Ill post up some of my experiences here when i have everything installed. I would imagine it absorbing every bump on the track with ease. As of right now, I'm just bottoming out real hard on the big jumps. Bouncing off the ground, and causing me to drift or correct myself.
#500
truck feels stable, planted on rough sections. but personally i feel this truck is way too light. when in the air the parachute effect seems to get to this truck more.. i really need to think abt cutting more holes in the body..
#501
the 112mm D8 shocks are too long, even with SNR rear towers, supposedly for big bore shocks. rear part the truck will bottom out on the shocks 1st. it can/may stressed out the mounting. i am using the shorter 97mm on both ends. white/grey for the front/rear.
http://www.amainhobbies.com/product_...re-Shock-Set-2
Even comes with stand offs.
My truck isnt light, I run 1/8 electronics, and a few other aftermarket products.. So its far from light. I also never parachute. I cut holes in my body.
If your truck is light, Do the Air vents as necessary, and add weights.
My Flotek works great for this truck.
#502
Im using the 97mm FRONTS on all fours, these fit perfect...
#503
#504
http://cgi.ebay.com/New-Ofna-Ultra-L...item5644b5f1b7
hey guys i was jut wondering if these shocks would fit the front and rear of the nexx? thanks
or would these fit? http://cgi.ebay.com/New-Ofna-Ultra-L...item4cf7c85cdb
#505
My current baseline for med-traction bumpy 1/8 tracks is 50w front 3/4 preload, 40w rear 1/3 preload with the stock white springs. Ride height and droop also play a large role in how bouncy/bottoming out it feels... adjust to find the happy place.
#507
stock shocks it is then
do the nexx and the scrt share the same rims?
i was thinking of getting these. http://www.amainhobbies.com/product_...k-2-Slash-Rear
#508
#509
I am about to order one of these.
I have a Castle sct combo with the 3800 4 pole motor.
What pinion do I need to order, I am new to EP.
Do I need mod 1,48p or what?
look forward to your replies
