17.5 Ballistic in an SC10
#16
what kind of track are you running that on Jeff? Here's a link to a video of my track. Small, tight turns, indoor, basically no straights.
http://www.youtube.com/watch?v=rq10Pa4vzyM
#18
#19
19/78 I would think would be in a hotter motor. My slash with the 26/83 had a FDR of about 8.5. Well if you want more lowend torque then try shooting for a FDR of 9 or 9.5. I ran a FDR of about 10.5 in my 10.5t ballistic and temps were great on a track with lots of stop and go turns.
19/78 in a sc10 will give a FDR of 10.5 roughly. I would gear higher than that in a 17.5t. 21/75 seems to be a close fit at 9.3 FDR.
Here is the site I am using to find the FDR easily. I usually dont pay much attention to the top speed section even though it will be in the ballpark.http://scriptasylum.com/rc_speed/top_speed.html
#20
#23
You have probably figured out by just plugging in some different motors that the motor doesnt matter in figuring the FDR. The motor on plays a part in the top speed. The FDR is the final drive ratio. Diff,trans,spur, and pinion are all that matters in figuring the FDR.
Just for figuring on the 17.5 I was using the hobbywing 2300kv. I think its pretty close to the 17.5 ballistic. I also noticed the associated spurs were not in there so I was just using the axial spurs for figuring the FDR.
