tenshock sc401  short course Brushless MOTOR >
Old 07-02-2011, 10:16 AM
  #451
lowroad's Avatar
Trader Rating: 79 (100%+)
wow. insanely fast.
Geared 13/40 on an scte with a 4000kv tenshock, and a xerun 80a 8th scale esc. This thing flies. It seems faster than I was with a Novak 4.5, for sure. Granted, not quite as smooth, but it's fine. I think with a real esc, I'd be in even better shape. I was clearing things at the track this morning that I wasn't making last week, I know that much.
The power is what I would call "instantaneous". I ran for a good 2 full battery packs, or about 20-25mins and temped at 165 on the motor, and around 125 on the esc. I'm happy with the motor.
lowroad is offline
Old 07-02-2011, 10:23 AM
  #452
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Originally Posted by lowroad
wow. insanely fast.
if you ran those packs back to back and got 165, it sounds like you could even go up a tooth or two for racing.
RC*PHREAK is offline
Old 07-02-2011, 10:54 AM
  #453
lowroad's Avatar
Probably. Especially considering it's 100 degrees or so here today. I'm not sure I will though. With the 13 on there, it's more power than I can use for the most part. I'm not sure I'm even getting to peak at top speed on the back straight. It screams though, for sure. and it's temping well.
lowroad is offline
Old 07-02-2011, 03:41 PM
  #454
Trader Rating: 26 (100%+)
you are running a real esc. the hobbywing is at least as good as any out there.
osobad is offline
Old 07-02-2011, 06:31 PM
  #455
lowroad's Avatar
yeah, it's ok. I had some issues. The switch broke, for one. It's smooth and does it's job. I'd maybe like a higher amperage BEC, but yeah, it's fine. I may need to play with timing too, because I experienced some of that "stall when stuck" issue the other guy was talking about.
lowroad is offline
Old 07-02-2011, 07:30 PM
  #456
Trader Rating: 83 (100%+)
From what I've read most people are running these in 4x4's. What say you about a 2wd sct (xxx-sct)?
Darren
dpcardoza is offline
Old 07-03-2011, 01:47 AM
  #457
RC*PHREAK's Avatar
i have read before that the xerun series of esc's don't do that great with non-sensored motors. for me, my SC8 has been awesome with my tenshock. no issues at all. my savox 1258 servo runs perfect. none of this mmp/external bec crap. motor is silky smooth (as smooth as sensorless can be).
Darren
if they would even fit, they would be complete overkill in a 2wd. for a great, budget 4 pole motor for a 2wd (and still does well in 4wd's), i think this motor would be a much better option: http://www.ckhobby.com/shop/?control...&product_id=61
Old 07-03-2011, 01:49 AM
  #458
RC*PHREAK's Avatar
wow. insanely fast.
i got to run my 4600 tonight in my newly converted SCTE. ran 12/40. after the 7 minute main, it was at 161. ambient temp was probably 80. more speed than i needed. totally happy with the setup at this point.
Old 07-03-2011, 03:01 AM
  #459
w00kie's Avatar
Could someone please tell me where i can get a new motor plate, front one, that the screws go into to mount it to the chassis.
i have stripped one screw each on both locations on the mount.
Im just after a spare plate.
thanks.
w00kie is offline
Old 07-03-2011, 05:59 AM
  #460
lowroad's Avatar
good call.
lowroad is offline
Old 07-03-2011, 06:38 AM
  #461
for those of you haveing the stall prob,have you tried a better or diff battery. We had the same prob with the 4600 and it did it no matter what esc we used even Tekin . It was the same thunder power battery each time. Swithched to a new battery and no stall.These tenshock short course are battery hungry. I use the 801 in 1/8 and it is very smooth and efficient. The hobbywing esc run as almost smooth in non senored mod as some do in sensored. right now the 401 is working very well with a hobbywing rc8.
osobad is offline
Old 07-03-2011, 08:55 AM
  #462
MojoManDan's Avatar
I raced my 4600kv yesterday with a MMP and Savox 1258TG for the first time in my SSC LCG Slash 4x4, and had help and advice from the SSC LCG designer, Mark. Great guy, passionate about what he does, and very helpful despite having his own races to tackle! He invited me to pit with him and his dog, Race.
I have nothing to compare this motor to, but to me it was a ground missile on pavement geared 13/52. In dirt, it was impressive....I probably needed better tires to put the power to the ground.
In 90 degree ambient temps, the motor came off a 5 minute heat at 100 degrees. The metal motor mount and metal chassis certainly helped dissipate the heat, along with a small heat sink I clipped on. I did not temp the MMP. I did not have any stall issues that people talk about when using the MMP and 1258TG. I guess I am lucky?
I don't see the need to use a different motor, as the only limiting factor with this combo is the driver (I SERIOUSLY need to learn how to jump!).
MojoManDan is offline
Old 07-05-2011, 12:00 AM
  #463
w00kie's Avatar
thanks.
COULD SOMEONE PLEASE HELP ME
w00kie is offline
Old 07-05-2011, 10:18 AM
  #464
I don't beleive they are selling parts for the motors yet. Is it possible for you to tap one of the stripped M3 holes into an M4?
brew99 is offline
Old 07-05-2011, 01:31 PM
  #465
Ridley's Avatar
You can take the front cap off and rotate it so you can use a different hole if you have to have the motor can turned a certain way. Then you can use a completely new set of holes, or the m4 holes. The m4 holes will require drilling out your motor mount plate a tad, but the m4 screws are more secure.
Ridley is offline
