RC8BE Tekno V4 chassis
#33
Can anyone confirm the use of a Futaba FASST Rx with the V4 radio tray.
Also can someone suggest a long shank pinion to move the rear weight forward as opposed to standard.
Anyone race frequently with this chassis setup with great results?
I know of one guy who ran the V4 chassis at the Roar nationals at Norcal, what was his name?
Last but not least does anyone know the total weight as opposed to the standard BE platform?
Thanks.
Thanks.
#34
Thanks.
Thanks.
#36
tekno
That sucks I have faast and this kit but haven't finished it guess I'll figure it out when I get there. I was wondering what diff mounts your using? I see they are aluminum I think the only ones i've seen are integy. I've blown out a few stock plastic ones. Also I'm just mixed on what to do with batteries I run a rx8 1550, I've run it on 5s and 6s 5 seems pretty damn good and I run large outdoor tracks, 6s was ballistic and ripped all my tires off the rims. Not the glue either it ripped the rubber. Would it be better to run the 5 or the 6 and dial it down on the transmitter.
#37
#38
one more question
I know its been asked other places alot but what about the plastic spur?? I personally like the idea of a really quiet smooth car. But I was disappointed to see tekno left it wide open on the bottom now I'm skeptical. I'm going to try it anyway just wondered if others had experience. I went ahead an went
6s for batts. I'll just dial it down a bit. On the center diff mount I would love to mill off a bit, but again not with the plastic spur.
#39
pictures
it gets boring without pics here is the progress so far.
#40
http://i786.photobucket.com/albums/y...nished_Top.jpg
http://i786.photobucket.com/albums/y...shed_Front.jpg
http://i786.photobucket.com/albums/y...ished_Back.jpg
#42
Tekno mudguards on snr chassis?
Can anyone confirm that the tekno mudguards have the same screw patern as the stock ae mudguards? Running a snr cf chassis and it's flat on the sides so the stock mudguards fit funky. I thought the tekno chassis was flat too but I could be mistaken. The tekno mudguards do look to be narrower than the ae ones and I think they would work but figured I would ask.
#43
#44
chassis
Then you can't use mech brakes though which I want, and I want the clutch. I really just don't see how the chassis could flex that much between those two points. Its not even the weakest point which is going to flex first. Still going to try plastic and just see how it goes.
