OMG Please help!!!!
#46
I don't use sensors, so I haven't experienced that, but it's good to know. Are you aware of a fix or mod that could make it less of an issue?
#47
R/C Tech Elite Member
Rifle has a remote control car park now It's still covered in snow right now but I'm chomping at the bit!
Here's a link to the thread here on RCTech http://www.rctech.net/forum/colorado...trol-park.html
You know that the Ute Indians here said there was a curse on Sopris mountain that if you ever slept in it's shadow you would be destined to return
#48
Proving me RIGHT when you have nothing positive to add to the forum IS???
Let me give you an example of how character works....
I spend time helping others (like the thread your on dick weed), I have made YouTube vids for people to explain how to solder the large 6.5mm bullet connectors and the difference between series and parallel. I have even sent free parts to people to help them out of a bind.
I run 7 RC's, Losi 8 buggy, Losi 8T-e, Ofna Hyper 10SC, Ofna Hyper 7, Losi XXXT, an Academy SB-V2 Pro, and an Axial rock crawler.
I can show you data logs from my Hyper 7 running 8S lipo with a Mamba XL and a 1518 motor doing 80mph pulling 111amps and only running a max temp of 118'f ESC and 135'f on the motor.
I have pic's and video's to back it all up.
People like you should just read, and not post.
Why would I have data logs or video of an esc that I no longer use and have not used in quite a while because it was crap to show you?
#49
Yes, I apologize for the name calling. It just frustrates me when a person like you comes onto a healthy thread and post up some junk that does no one any good. Then when your called on it your response is what I liken to a 5 year olds "I know you are, but what am I?"
I understand you have no castle products. My question was what DO you have?
Can you exhibit some kind of evidence that my claims of your character are mis given? Can you show some evidence that warrants considering your opinion of this or other RC related products?
You should read back through this thread and note that everyone until YOU had something positive to add or some logic that would help the OP to some form of resolution of his problem.
Step up your game, or just go away.
#51
Sorry B.mcdaniell.2009, I should have just not responded. My bad...
#53
I have the MMP ESC & Novak 550 4.5 motor installed in my slash 4x4 and I was also experiencing cogging when the truck start from a dead stop. The way I was able to fix it was by buying a "Spektrum Voltage Protector" (SPM1600), it plugs right into the receiver and is installed right in the receiver box. Now there is zero cogging and is running perfect.
I am also using a Associated DS1015 servo with a Futaba 4PL remote.
My settings for the MMP ESC are: (Setting are off the CastleLink Programming software)
--Basic--
Cutoff Voltage: Auto-Lipo. Auto-Lipo
Volts/Cell: 3.2 Volts/Cell
Brake/Reverse Type:Proportional w/ Reverse Lockout
Motor Direction: Normal
Brake Amount: 60%
Drag Brake: 0% Disabled
Punch Control: 0% Disabled
Reverse Throttle: 50%
Power-On Warning Beep: Beep Enabled
--Advanced--
BEC Voltage: 6.0V
Arming Timing: 1.5 Seconds
Throttle Dead Band: Small (0.0500)
Start Power: Medium
Motor Type: Sensored Only
Through the "Quick Field Programmer Card" I adjust the "Motor Timing Cheat" to 4* (Low)
With no adjustment to Throttle or Brake Curve.
Hope this will hope somebody having issues with the MMP & Novak 550 4.5 combo.
--Basic--
Brake Amount: 60%
--Advanced--
BEC Voltage: 6.0V
Start Power: Medium
