does acetone hurt the tire / wheel /insert >
Like Tree1Likes
Old 11-26-2013, 10:06 AM
  #31
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Naters
I've had foams wear out before the tires. I acetoned the tires, sealed in an old paint can with the tires elevated out of the solution with shot glasses for about 48 hours. Fumes dissolved the glue and tires came off clean. New foam, remounted and the tires hooked.
Originally Posted by Wild Cherry
acetone , even its fumes dries out the oil
in the rubber and ruins the tire
Just skin the tire off one side of the rim with a X-knife .
Easy to do and only takes a few minutes..
I agree with Cherry (holy crap I just said that)
If you're only looking to re foam a rim and tire, cut the back side as close to the wheel as smooth and cleanly as you can. Pull the foam out, replace and then re glue. Lining up the cut line. The bond will be better on the tire cut than on the original wheel/tire glue joint. Once you get good at this you can do it 2-3 times on the same tire for testing.
racer1812 is offline
Old 11-26-2013, 10:09 AM
  #32
fq06's Avatar
Very close to no residue left. The one piece literally popped right off with the twist of the exacto blade. The channel is just like the rim was brand new. No work involved really, sit the wheels in a pot of boiling water, grab a beer and watch a game or a show and come back to remove them about 30 or so minutes later. Virtually 100% (99.9% maybe ) of the CA is left on the tire.
Here is a video of the tires before and after a debonder soak. Can't embed video for some reason.
http://youtu.be/1qVbukHru2U
fq06 is offline
Old 11-26-2013, 12:13 PM
  #33
lodhammerdin's Avatar
Trader Rating: 77 (100%+)
Originally Posted by racer1812
I'm a fan of Acetone when just looking to get a dead tire off a rim. But NO CA I've ever used has come off in Acetone in an hour
I don't want to say bad glue job or bad CA but I don't know how you could get them off that fast with Acetone..?
I use 70% acetone. My wife if a cosmetologist so she can get me the good stuff. I just have to make sure to wear gloves and rinse the tire and rim off throughly or it will burn my skin.
lodhammerdin is offline
Old 11-26-2013, 12:15 PM
  #34
Originally Posted by homershoots
Same here but I do re use the foams , used foams usually feel better on my 1/8 anyway.
I re use the foams to, I was kinda implying that when I say I cut the foam out so its not ruined.
Old 11-26-2013, 02:35 PM
  #35
Super Moderator
racer1812's Avatar
Not "good stuff" would be.??
Old 11-26-2013, 02:37 PM
  #36
fq06's Avatar
That's the stuff that doesn't remove skin on contact
fq06 is offline
Old 11-26-2013, 04:55 PM
  #37
The more pure the acetone is, the better it works and faster it works. Normal acetone from a store is like 5 and 10%.
Elies12 likes this.
Old 11-26-2013, 04:56 PM
  #38
Haha, this too.
Old 11-26-2013, 05:16 PM
  #39
ThePanda's Avatar
Trader Rating: 68 (100%+)
I have had some wheels warp with the boiling method.
ThePanda is offline
Old 11-26-2013, 08:48 PM
  #40
fq06's Avatar
That was the over night method, you want to shorten up the duration of the boiling stage
I guess it can happen, I've done multiple DE's and a set of aka's without any issues. Wasn't aware of anyone damaging a wheel boiling.
fq06 is offline
Old 11-27-2013, 05:20 AM
  #41
kylehirano's Avatar
Trader Rating: 14 (100%+)
Boiling is a term used loosely, what they really mean is to simmer them in a light boil. Rapid boiling can ruin and warp plastic. Boiling a wheel to get a tire off is a bad idea. You can never get it off clean, ther will always be CA residue
Also acetone will ruin your foam inserts, I don't care if it's open cell or closed cell foam it will destroy them.
kylehirano is offline
Old 11-27-2013, 05:33 AM
  #42
ThePanda's Avatar
I did a by the book boiling. Gentle simmer, left for 45 minutes.
I was able to chip off any residual glue on the wheels and tires. Though, I did have to filet off some more stubborn pieces off the tires.
ThePanda is offline
Old 11-27-2013, 09:04 AM
  #43
JeepnMike's Avatar
Trader Rating: 17 (100%+)
While we are on the topic, is there anything I can do to keep the beads of my tires from seeming to "crack" and break down where the CA glue is? Even on 1 run tires they seem to degrade at the bead. Maybe I am not keeping them clean enough?
JeepnMike is offline
Old 11-27-2013, 09:10 AM
  #44
ThePanda's Avatar
Are you glueing down in the channel of the wheel? That is where the gluing should take place. You shouldn't be able to see any glue when you are done gluing too. Glue should be down in the wheel bead, and on the wall of the Chanel. Of the wheel.
If you get glue on the outside of the bead, the tire will flex, and the glue and tire will crack.
ThePanda is offline
Old 11-27-2013, 06:51 PM
  #45
ta_man's Avatar
Trader Rating: 168 (100%+)
My experience over 6+ years of using acetone to remove tires contradicts your assertion.
ta_man is offline
