does acetone hurt the tire / wheel /insert
#16
I boil, rims come out clean and CA debonder takes the glue off the tires if I'm saving those.
I was saving the rim on this one but they come off the same cut or not.
http://youtu.be/L6As0M9AcoQ
#17
On YouTube a poster by the name of squirrel a sponsored pro-line driver posted a how to remove tires from rims. Either by boiling or baking.
#18
[QUOTE=RC10Nick;12758355]you mustn't live with anybody else. baking tires off fumes the whole place up.]
Lets both do our methods in the kitchen and see who makes more fumes lol. After baking the glue chips right off extremely easily. I re-use the foams with no issues but to each his own.
#19
Trader Rating: 77 (100%+)
I just cut down the middle of the tire once its no good, take the foam out, and then soak the tire and rim in acetone for an hour. No issues for me there. I dont really know why people want to take tires off of rims just to remount the tires.. I only take tires off of rims to reuse the rims, not the tires.
#20
#21
Removing tires from wheels
The process takes anywhere between 24 and 48 hours depending on how much acetone is in the bucket...so if your not in a hurry and are looking for an easy way to remove tires from wheels,try this,you might like it
#22
Super Moderator
Trader Rating: 31 (100%+)
What surface are guys running on that a tire will outlast a closed cell foam?
#24
Hmmm...
#25
Super Moderator
#26
Super Moderator
I don't want to say bad glue job or bad CA but I don't know how you could get them off that fast with Acetone..?
#27
I've had foams wear out before the tires. I acetoned the tires, sealed in an old paint can with the tires elevated out of the solution with shot glasses for about 48 hours. Fumes dissolved the glue and tires came off clean. New foam, remounted and the tires hooked.
#28
in the rubber and ruins the tire
Just skin the tire off one side of the rim with a X-knife .
Easy to do and only takes a few minutes..
#29
There is not much glue left if any on the tire on the outside, some left on the inside of an SCT tire. I will post a short video of the tire after soaking in debonder for a little while. Touch less and zero CA with a clay tire left in perfect shape.
Acetone prices have gone up quite a bit, water is free and debonder is not that much $.
#30
Super Moderator
Actually, it does. I turned the rim to show the one piece of CA that was hanging on I guess because a little bit if the foam got CA on it. That popped right off with the twist of an exact blade.
Maybe if a guy is doing one or two stets of rims boiling may be better/faster. Don't know never tried it as it seems like more work to me.
Only thing I want to save is the rim and CC foams so cut the tires off and put 10-15 sets of rims in a bucket at a time. Day or two later I pull the mout and wipe an CA "slime" off. (and always wipe with motor spray before remounting tires!)
