#1426
Salad I did this mod on my Ten chassis awhile ago, give it a try...copy and pasted from an earlier post...http://www.rctech.net/forum/8291057-post707.html
I thought this might be useful to some of you on here...the area on my 10T chassis where the droop screws ride was getting pretty chewed up, so I installed the Losi 2.0T droop screw pads in my 10T chassis.
This was very easy to do and will save the chassis from excessive wear in that particular area, after drilling and taping the 4/40 sized holes I simply applied locktite and threaded them in
Part# losa6253 http://www.amainhobbies.com/product_...Droop-Screw-12
Peace
Peace
Really trying to resist getting this since I already have the 22 on order. I've read about the heat issues when running the RSpro with the 550 cans, but I'm wondering if it would work with the Castle 1410? Anyone tried this yet in a conversion? Any input Trey? Thanks in advance
I used a max of 3, I think... Curious to what the pro's are using.
#1427
Doesn anyone know where i can get a 19T Pinion that fits 1/8" shaft off the castle pro 24kv motor? Do i have to get a sleeve? I want to know what the Losi drivers were using when they were testing that motor...Thanks!
#1428
http://www.nitrohouse.com/p20819/Hyp...f222a9998b3685
I use a sleeve they work fine.
And the 1415 has a 5mm shaft, you won't need the sleeve.
#1429
[QUOTE/]Good question, I have not tried the RS Pro with the 1410, I should since it has some turbo he he. I'm about to pull that setup from my SC10 anyways, my 9 year old doesn't need a $200+ speedo to help him fly into walls. If I get a wild hair and drop that in and test it I will let you know. [/QUOTE]
Nice! Hope that hair finds its way. This might be a way to make this happen for me. Thanks. I'll keep watch for any updates...
#1432
to SALADFORK
Last edited by hgrove99; 02-26-2011 at 02:48 PM. Reason: Wich sleeve should i use?
#1434
Thanks for your time
#1437
It looks like a monster truck in travel mode. Lol.
You still diggin the 1410? I'm going with the 1410 on 2 cell 14/40 ( when my spurs get here, I was hoping for today but will be Monday or Tuesday). I wish we could run 3 cell. I would love the 1415 in this thing.
Hey I just thought you can run your nanotech's now. Just get the stock SCTE battery tray and cut the rear out, wha-la!!
#1438
#1440
I did order the new battery tray, not sure if the holes will line up. If not I planned on drilling it out. My 3S packs are brand new, its sucked not being able to test them.
