That and with a 2650KV he is limited on a big track with just a 21T pinion. A 23T would likely provide enough top end to do some serious damage on a larger track....that or step down to a 17T and run 3s battery.
On the smallish tracks, it is pretty hard to keep up with an 1/8th scale motor coming out of the corners if you can keep it hooked...just gobs of torque!!!
Chris is just fast....
He mentioned that the t8 2650 on 21t/no timing was still plenty fast on the large outdoor track. Going from indoor lighting to out door dark spots is hard to do. He did tq though and had a big lead in the main. Then started catching pipe when he would lose it in the dark spots.
night driving advice
Here's a vid of the new layout at Revs. Fun layout, but can be tough on SC trucks. New layouts are always a little tough at first.
I was having issues, especially under the lights, on the backside triple triple. I was taking it as a double single triple (which is a good line), but there were times from the driver stand where I just couldn't line it up or I would lose orientation of the truck for a second and it would cost me in turns or setting up for jumps (you'll spot at times where my cornering is slow, or obviously the second time I hit the triple I was way off line).
Those of you that run on larger tracks where sight can be an issue, especially at night under lights, other than more practice, is there anything you do to make it easier to stay consistent?
+ YouTube Video | |
I can't watch youtube on this computer but a bright body always helps to see your car better at night. White or yellow bodies for night racing I found are best. Something bright. After that it is just practice. Not much can be done to help with loosing your car in blind spots. I try and position myself on the drivers stand to be closest to the hardest spots on the track. If there is a tricky triple or whoop section or something that is a little harder the the rest of the track try and get the best angle on the drivers stand for that section to maximize your view. In the end, pratice will help you learn how to control your car during that black out period to be more consistant. Cut the track and do that section over and over a couple times if you can is another trick just so you get that hard part down.
Might be dumb question.....Is it legal to have a bright LED right on the roof? Just a thought
Or maybe some reflective stickering on roof...I know I'm blind as a bat at night as it is.
Salad....can you imagine the force that is being generated on those blades?
Any of you guys in a HOT climate? Here in Texas it is hot already, real hot....my trusty 1415 w/MMP is temping 165-170 running just a few minutes. Just fried my daughters little Titan 550 motor in her bandit after a 3 minute play session. Temped the street and it was 130.
Just how effective is cutting body holes along bottom of window and a few in back? Is it normal to gear down when your in a hot climate?
1. Super bright body. Flo Yellow is the very best hands down.
2. Have a black straight stripe on the top of the truck from the hood all the way back. Having a straight orientation line lets you pick up subtle changes in direction better.
3. Stand on a bucket or stool. Elevation always helps your visability. May not be a big advantage at your particular track, but tracks with driver stands on the verge of being too low....it REALLY helps. And, of course, when visability is at it's worst, like at night, is when it helps the most. It's amazing to me how much an extra 2 feet can make
There's 3 things you could try, that I have found helps me out quite a bit at night.
Don't have time to compile data.....same indoor track, same layout, same motor and ESC set-up.....175degrees with grease 140's when I changed to 5-5-3. As far as handling, the grease pushed like crazy and didn't rotate well through the corners. The grease is definately thicker than my current set-up of 5-5-3. Maybe I'm one of the lucky souls that received a better truck...lol...I switched out my pins after 3 packs....40-50 packs on it before I did diff rebuild and everything looks perfect....no wear on my blocks, gears like new and it's smooth as butter.
+ YouTube Video | |
I've never heard of any track not allowing a person run due to LED's or reflective stickering. I'm not sure what ROAR's stance on it is, but I doubt unless you're running at Tebo, Cavalieri and Mayfield's level would any track not allow it. Even at the big races, in the sportsman classes I'm sure they'll overlook it. Now as far as it being distracting to other drivers...I'm not that good of a driver, I'll take any advantage I can get...hmmm...maybe I should start running some LED's
On another note, the new layout at Rev looks SUPER FUN!! I haven't been there since I ran onroad way back when they ran onroad there. I go to OCRC and my car's are always nice and clean afterwards, but this layout makes it look like it might be worth having to break it apart and clean it afterwards lol Maybe I'll have to take a drive out just to check it out sometime soon.
And man, onroad at Revs, that was way back in the day before I even moved to LA...
