#9872
Suspended
#9873
Suspended
#9875
Suspended
oh i see my brother just showed me the pics that everyone thinks is the same person. dont take this out on me please
#9876
When you run the 1415 motor on 2s you will need to go bigger to get speed the kv is only 2400 I think
#9878
What is the biggest pinion that will fit on the SCTE?
I got my Castle 41415 2400kv motor mounted, but sure doesn't have the RPM's that the 4.5 had on a 2S. Need to pick up a pinion reducer and Mod1 pinion though, thinking I will start with the biggest that fits and work down....... I have from 12T-17T already.
#9880
If my eyes aren't mistaken, it looks like the lightened outdrives are now available! Looks like another weekend of rebuilding diffs for me The good news is, this is the last time I will need to crack them apart for a while. Race this Saturday, but will rebuild after that. Then I get to sit back and see what else Losi will release for this truck
#9883
As far as pinion size I'd say start with a 14 and watch your temps you may have to go down a tooth or up a tooth
#9884
R/C Tech Elite Member
The stock settings are a pretty good starting point out of the box.
I would update to the latest 212 software... but start out with the stock settings in the controller and then fine tune later for your personal feel.
Also... Set your Lipo Cutoff for the battery you are using.
Most of the settings in the RX8 are for feel / power delivery... The factory settings are more than adequate until you are ready to start tuning for feel.
Check out the Tekin RX8 thread in this forum section.
-David
#9885
Suspended
sorry to cut in but just wanted to ask. i saw a 1/8th scale tekin rx8 motor that was 1700kv? now i am just asking here why is the kv so low, doesnt this mean rpm and the lower the kv the lower the rpm? i thought you needed more kv for power on a heavy 1/8th scale rc, please explain this to me, thanks
