#8191
The 2400 is a dog on 2s. 15t might be a touch low, 16 might be perfect, 17 might be very close.
#8192
Not the best by far, but fun none the less. The track was pretty loose. I actually had the stock tires on.
+ YouTube Video | |
#8193
Thanks bro. Yeah it's a really fun track.
#8195
Yeah, it's in Union City CA.
norcal-hobbies.com
norcal-hobbies.com
#8197
You should. It's a world class facility. The 1/10 nationals are going to be held there this year as well as the 2nd straight year for the reedy race.
#8198
There will be another one shortly here...
#8199
Sat night race report ,Truck ran awesome again.Small indoor clay track,new Losi pins installed no damage nothing broken ,bent or tweaked,Truck ran flawlessly!Ran 3rd behind two sponsored guys so I guess 1st for the Joes!
Temps with the 14 t pinion at 145 after 5 min qual and 7 min main, RX8 & 5.5 scx4x4 motor.What more to say than, 2 months of racing and still having a love affair with this truck
The only reason u did good was cuz I wasn't on the track to wad ur truck up foo! Lol jus kiddin u were movin out last night bro.
On another note.....anyone know where I can get a set of spider and side gears? All of my local shops are backordered and can't get them.
#8200
on the other hand tho, my faith in mmp's has been shakin pretty bad, both of the speedo's I bought this last tax season have ended up being junk. It just stop working and it never even got hot. nice still have some older ones that never gave me any problems, weird.
just curious if the speedos cool, battery was cool, motor hot, don't that mean I'm under geared for my track. wouldn't think that would be the case considering I never really could top it out. and a 23 tooth pinion, crazy if that would be the case.
#8202
What ev! Wish my losi was running. Front diff gears stripped out in practice yesterday. This is my second weekend with out my. 4 wheel. I now feel like a dope fiend without his methadone!
I have no idea why this is not in the first
post on this thread yet??? But here you go...
From A-Main
OFN21003 - gears and pins (only using the small bevel gears and pins..)
KYO96775 - Kyosho bevel gear washer/shims or any 4x10x.15 washers
You will need two of those behind each bevel gear to help things mesh properly. At least that's what mine needed.
Just basically pull the losi or AE pins out and toss em on the side.. Same with the Losi gears, tiny washers and aluminum bushings and replace with OFNA gears, Kyosho washers (or equivalent). The shafts are a touch too long. You will need to trim equal amounts from both ends of the pin. It is nothing major, it isn't so much that you need to cut it off with a wheel. Just a touch on the grinder or dremel tool and all will be good.
#8203
#8205
From A-Main
From A-Main
Now what do I use for the flat side gear? I has a lot of flat spots on them.
