Man those Nanobytes smell nasty. Betcha they are carcenogenic.
Use soft wide ones. I have used AKA reds on a multisurface. The outer edge has no ribbings like the Schumacher Minipins I guess to prevent traction rolling.
I dont know about the D-Boots tires of what foams to run . If there a soft compound im guessing you would use a Medium insert if there harder you would use softer inserts . I just use whatever comes stock with the tires i use.
I do have a question about running on the carpet to stop traction rolling im going to try the upper link on the Front shock tower would that really help with traction rolling ? Im using SC10 tires up Front and Pressure points in the back which one pair is soft and the other is Gold traction rolls on both compounds if i try to drive a little harder.
We cut the outer rows off the Schumacher mini pins anyway. Looks like I can't get any nanobytes until late april. I needed some tires this weekend. lol
all the labels read "proven to cause cancer in Cali"
soo if you're in another state its ok!!!lol
Adjustable Front Hinge Pin Holder Set (TLR KIT)
What angle give a .5, 0, 1 holder in kit ?
thanks
thanks
You may want to DL this sheet, it has all the angles as well as explaining what they do...
http://www.tlracing.com/ProdInfo/Fil...uning_Tips.pdf
Is anyone running that new Tekin short course motor?
what I did was align the stock peaces and then went from there but knowing the rear end is stock at 3 degrees you can add or remove using 0's to start at stock. or read up on Hackers post for set ups. works on both 2.0 or 1.0 scte
is there a review of this chassis and what are the main benefits ...other than the ones posted on the site.??Would love to know cause I run in a indoor clay track .....has anyone bought this,installed it and can give us a first hand account ? I ask because my wife got it for me as a b-day gift for my losi....without asking if I wanted it.It looks so nice that I can perhaps like it if I do instal it. Any info would be appreciated,thanks.
I just got done modifying my battery box to slide the battery rearward, and it was very easy to do. I also trimmed off unneeded material as well. I would down load a picture if I could figure it out.
What do you think of this mod?https://mail.google.com/mail/?ui=2&i..._0.1&safe=1&zw
Just go to http://www.imgur.com and use that to upload your photo.
Smartdiff?
Does anybody know if the Smartdiff from losi will fit in the SCTE (center/ front), just going threw and rebuilding, if its an upgrade I'd change them out.
