#4411
I run the 1512 1y and it runs amazing. For being a larger motor and running it on the lower end of it's capabilites it sure does run great. Not too much torque doesn't pull the front end up very easy. It has great top end was about to run a speed test to get exact numbers but my truck stopped going forward( diff pins?) I would guess it will go about 37 mph on a good 2s and around 43 mph on a good 3s. Which IMO is FAST. When I get my truck fixed will put down some exact numbers. Heat is no issue at all. The motor is a little warm to the touch defiantly not hot to the touch after a good 5000mah pack or two. I am pretty happy with this setup. I did grind the little motor stand thing a little and took a bolt out and it slid right it. Using a novak 20t pinion installed upside down to fit. Easy install. I ran it at a smaller indoor track( not my fave) and it ran great, a little fast but the truck can handle it. I hope to get more track time in asap.
#4412
#4413
I have stock replacment Front & Rear shock towers and Aluminum Front and Rear Chassis brace for sale.
Looking for what I paid for them, the shock towers are new in package, I took the braces out to see them on truck but never ran them.
PM me if interested
PM me if interested
#4414
Is today - " Diff Replacement TUESDAY"??
Is this the Tuesday that all the replacement diffs are shipping? Inquiring minds want to know
#4418
#4419
I just purchased a new steering servo for my SCTE. The guys at hot rod hobbies recommended the Airtronics 94780M. Its overkill for the truck but oh well.
I haven't experienced any glitches with this servo so for the guys running the MMP SCT combo or just the MMP esc and are experiencing glitching issues with their servo's, just wanted to let you know that the Airtronics 94780M is a great high torque servo that works perfectly on my MMP SCT combo.
Also, I may get flamed for this, but I just purchased a Stampede 4x4 to bash around with lol
Workin' on dat!!!!!!!
OR possibly something in a burnt umber??? LOL!!!!!!!!!!!!
#4421
yes i got the 1512 in there but i raised the center diff with 1/8 shims to get it in there. if you go back a few pages i got pics there that show there is space before it hits the center diff outdrive.i suppose you dont have to raise the center diff if you cut off the motor kickstand . i didnt do that as i have the 1410 2S 4 pole coming soon.
#4422
Battle of Attrition
My buddies and I are Saturday morning track hounds. The standard SC 4x4 setup has been Slxxh 4x4 running Mamba Monster ESC and 1800kv on 3S 5000mah. Nothing organized. Last one to hit LVC and/or break is the winner. The Mamba Monster setup has been the default because it can run pack after pack without any heat problems.
I recently jumped ship and traded up to the SCTE. I'd like to try a sensored setup. My question is, will a Mamba Max Pro/550 5.5 setup handle this kind of abuse? Would a Mamba Pro/Tekin T8 be a better option?
I have a Ten T running a Mamber Monster/2650 that is a proven setup, but as I said I'd like to try something sensored, just not at the expense of getting smoked figuratively and literally.
#4424
one day, the rain will stop...
